![]() Join Date: Mar 2000
Anybody used this Porterbuilt cross member
I'm looking at this Porterbuilt trailing arm crossmember.
http://pbfab.com/63-72-trailing-arms...ece-driveshaft I really like the simplicity and neatness of it. It's adjustable and you can compensate some for wheel center position, and pinion angle. It's probably light too. The price is reasonable and the shipping isn't bad. I'm slightly hesitant as there is a lot less structure there than on a stock crossmember. I will be putting a 6.0 in this truck and will eventually upgrade to LS3 heads and a cam that should put well into the 400's for HP. All of the force required to move the truck is transmitted through these two tubes into the frame. My gut tells me it's strong enough but I'm still slightly hesitant to pull the trigger. Any opinions are appreciated.
Saskatoon, Saskatchewan Canada |
I'm just glad to be here!
Re: Anybody used this Porterbuilt cross member
Lots of people have used this in their trucks. If you are concerned with the strength, contact Nate at PBFab. He can answer all your questions.
My gut tells me it will be fine at your power level.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I would believe you will be fine. by the design of round tube vs stamped steel I would say 400hp is fine but call PB and double check.
I have 508hp on stock cross member and arms but I was knocking out rubber bushings. now truck is apart going get a upgrade. |
