![]() Join Date: May 2015
WTB Charcoal Canister
Just realized one of the ports on my canister is broken off. Anyone have a good one they are willing to part with?
Re: WTB Charcoal Canister
I might will check and let you know in the morning
![]() Join Date: May 2011
What year 71 or 2 I think they're different.
Its a 71. Should have 3 connections. On the one I have the center PCV connection nipple is broken off
Carpe manana
![]() ![]() Join Date: Dec 2010
I have a 72 that I believe has three ports I could spare. It came from my blue blazer.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: May 2016
I have one you can have but I need to verify which one it is.
I have my old one as well. But depending on what you're building you may want to get a replacement one from NAPA. I can get a part number from the one I bought. Nearly identical.
I searched and searched but could only find 73 and later. Not sure what the difference is if any. Even the Corvette restorers dont have the 71-72 version. I came across a lot of "discontinued". If you have a part # that would be of great help..
Here it is
Carpe manana
Here's the one I removed from my 72 Blazer and the box with part numbers for the NOS piece I replaced it with.
The OP might try drilling out the broken port so a piece of steel/brass/whatever tubing can be inserted and epoxy it. Nothing to lose...
#13 |
#14 |
