To Cup or not to Cup
Hello,
I currently have my '65 short step torn apart awaiting my airride kit (getting delivered today). It is a BC Fab Level 3 kit (which come plates for top of bag and bag cups for bottom). My truck currently has 2.5" drop spindles but, I cannot decide on whether or not to cup the LCA's. I by no means want to lay frame. I like them low, but I like a stance. I'm just concerned it might not be low enough with the bags sitting in the stock springs pockets. I have also read that cupping them allows for a little better ride at ride height? Attached is a pic of my truck with the static drop...can anyone let me know about where it will sit in the front with the 2.5" drop spindles and bags sitting in stock LCA spring pockets? Will it get much lower than what it already is? I don't really want to trim inner fender wells and the tires are 205/75/15. Thanks! Last edited by bpope; 06-20-2018 at 02:18 PM. |
Re: To Cup or not to Cup
If it sat this low in the front with the setup I have...I would be happy.
Giving an update here. Well, I got the bags bolted on and jacked the LCA as far as it would go and it really doesn't seem low enough. I don't really get it as seeing pics of other trucks with the same setup, they seem way lower. I have a pic of another truck (Malibobs) that has the exact same setup as mine - but mine doesn't look near that low. Would it get lower with the weight of the truck on it? Doesn't seem like it would. Any help would be greatly appreciated. The lower cup mount that came with the kit is 1-7/8" tall (BC Fab Kit). I would want it to ride at the height of my pics attached...not when it is aired out. Bags are Dominator 2600's. I have 1-1/2" before the top of the tire hits the inner fender well (as it is pictured here - have not put the truck on the ground yet, just jacked up the LCA as far as it would go.) Tires are 215/75/15.
I cant help on the actual height questions.
The bags are designed to be used at the height they are when there is no pressure applied. By cupping them you can both improve the ride while having a lower ride height as well as air out lower. If you want to see how low it will be when you cup it you can take the bag out and jack the wheel up to whatever height you want. You will eventually run into the inner fenders (as you mentioned) as well as the steering shaft too.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#5 | |
Do you have the bag hooked to the valve or the shipping plug in the bag when you are raising the lower arm? The air naturally in the bag could still be compressing and not letting it fully deflate.
The shocks could be stopping its travel or it could also be the ball joints binding. With just cups, 2600 bags and plates my 78 puts the a-arms about 1/4" off the ground. I know the trucks are different but the suspension design is basically the same.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#7 | |
Ya they are stock, just removed the bump stop and its bracket, moog problem solver ball joints and poly bushings.
Cool. Thanks for the info. I took the bags out and am having the LCA's cupped. This will be as low as it will go since the tires are bottoming out on the inner fender well and this will be low enough for me!
low n' slo
![]() Join Date: Mar 2009
so howd it go? cupped is the way to go and an easy few inches of drop
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
I have the stuff to cup mine but I haven't done it just yet. I mainly want to do it so the bag is positively located at the bottom. My cups move around sometimes, mainly if I air it out on unlevel ground. Then I wind up with uneven pressures to get my ride height and the ride quality suffers as well.
#13 | |
#14 |
Needs more triangulation!!! Wait, I thought we were talking about a full cage...
1986 GMC K3500 Sierra Classic http://67-72chevytrucks.com/vboard/s...d.php?t=727677 Rides rough, sounds tough, and tows stuff.... |
#15 |
Uhmm….. Huh?
#16 |
Funny this pooped back up. I wound up getting in an accident (inattentive driver) that ruined my pass side front suspension. I never got around to cupping my stock arms an I have choppin block arms on it now. It lays the crossmemeber on the ground now, with 40 psi in the bags still...
