Old 06-20-2018, 02:14 PM   #1
theastronaut
theastronaut's Avatar
'51 GMC Restomod Finished!
I'm pretty much finished building a '51 GMC 100 for another local business. They had the truck restored around 20 years ago but it never was reliable so they didn't do much with it. They brought it to us to be updated underneath while keeping a fairly original look so they could finally get it out and enjoy it. I used Mustang II front suspension, TCI's Parabolic rear left spring/shock kit, an Explorer 8.8" disc/lsd axle redrilled for 5x4.75", a 5.3/4L60e from an '06 Avalanche with a PSI harness, Tanks Inc rear mount tank, Vintage Air Sure Fit kit with Kwik Performance compressor bracket, Ididit tilt column with a '54 wheel shrunk to 15", Lokar floor shifter and e-brake, and all new glass and weatherstripping. I kept the old paint and door lettering since it was in pretty good shape and only had to touch up a few areas. I did scuff the whole truck after fixing/blending base over the repaired areas and shot a couple coats of slightly flattened SPI Universal Clear.
theastronaut is offline   Reply With Quote
Old 06-20-2018, 03:36 PM   #2
8man
Re: '51 GMC Restomod Finished!
Oh wow, that is one fine truck!
8man is online now   Reply With Quote
Old 06-20-2018, 06:02 PM   #3
MiraclePieCo
MiraclePieCo's Avatar
Sunny beach, that is nice! I love the seamless blend of old and new.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-21-2018, 12:27 AM   #4
Matt_50
I'm so jealous, that looks amazing!
What color brown in the dash?
1950 Build
Matt_50 is offline   Reply With Quote
Old 06-21-2018, 12:52 AM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
very nice .....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-21-2018, 01:45 AM   #6
caseyjones
That is a great truck! What are the wheel and tire specs? I've got the same suspension setup planned and am about at the point of ordering wheels.
Thanks!
caseyjones is offline   Reply With Quote
Old 06-21-2018, 02:24 AM   #7
joedoh
joedoh's Avatar
really beautiful! I really like the Cibie style euro lenses
those are con2r gauges right? I thought about calling them to see if I could get a plug in set for the 03 donor I have right now.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 06-21-2018, 04:37 AM   #8
tmoble
Pretty cool.
Are you saying you shrunk the diameter of the steering wheel? got any info or pics of that process?
tmoble is offline   Reply With Quote
Old 06-21-2018, 10:48 AM   #9
b-mac
b-mac's Avatar
Curious about the rear-end re-drill: Since the rotor slip over the lugs, do you have to have rotors re-drilled when you replace them, or is there a better answer for this?
b-mac is offline   Reply With Quote
Old 06-21-2018, 11:00 AM   #10
theastronaut
Thanks for the comments!!
The dash was painted ~20 years ago and was still in good shape when I started the refresh. I did have brown paint matched for the wheel, column, and A/C panel but it was custom mixed to match the existing paint so I didn't get a code.
Thanks!
They're Wheel Vintiques smoothies, 16x7 and 16x8 with 4" backspacing on both. The tires are 215/70-16 front and 235/70-16 rear. Standard baby moon caps with GMC decals we had made to look similar to the original caps. I did have to use a 5/16" spacer in the rear to clear the bed side, and I made adjustable fender braces in the rear to push the fender out for a bit more clearance on the outside. It has fiberglass fenders; steel fenders may have a thinner lip around the wheel opening.
The Cibie's are great; they look pretty much like a sealed beam but out-perform many modern lights. Those are Con2R gauges, we picked them since they fit the style of the build really well. The mounting tabs needed a bit of trimming to make them fit.
Originally Posted by tmoble View Post
Pretty cool.
Yes, I found a 15" wheel on eBay, cut the rim off, and grafted it to the original steering wheel spokes.
Here's a post with more info on that.
http://67-72chevytrucks.com/vboard/s...12&postcount=7
Old 06-21-2018, 11:04 AM   #11
theastronaut
The axle was bought from a local street rod shop already rebuilt and drilled, ready to go into the chassis. I don't remember if they used rotors with the correct lug pattern or if they're also redrilled.
Old 06-21-2018, 04:27 PM   #12
Donaldo
Well done ! REALLY NICE !!!
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 06-22-2018, 12:23 AM   #13
Softpatch
Softpatch's Avatar
that's nice....any chance we could see the under sides.?
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 06-22-2018, 09:22 AM   #14
Volfandt
Nice job. Looks like it would be a great cruiser.
I really like the steering wheel, great mix of old school looks and modern size.
Volfandt is offline   Reply With Quote
Old 06-22-2018, 08:38 PM   #15
theastronaut
Thanks!
I didn't take any pics while I was building it, and I don't have a lift to take pics now. Its nothing special underneath, I had the frame powdercoated but it's not really detailed well. Just meant to be a daily driver level refresh so I didn't spend much time making things look good underneath.
Old 06-25-2018, 12:19 AM   #16
evilokc
beautiful.
evilokc is offline   Reply With Quote
Old 07-06-2018, 02:27 PM   #17
solidaxel
solidaxel's Avatar
Very nice G M C and the right combination!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-07-2018, 10:23 AM   #18
Advanced Design
Advanced Design's Avatar
Beautiful truck. Nicely done!
Advanced Design is offline   Reply With Quote
Old 07-08-2018, 03:58 PM   #19
Black_Sheep
Black_Sheep's Avatar
Well done!
Black_Sheep is offline   Reply With Quote
