I may be able to purchase a wrecked 96 Impala SS really cheap, has anyone put the lt1 motor in their trucks ? If so what do I need to do to have a speedo (the over-drive has wires but no cable) is there a sender that will fit in the tranny so I can hook up the cable.
i dont know but there are people here that have them... you have to use a speedo for the lt1. either the factory one or an aftermarket one.
70 longbed 496/th400/Ford 9" |
The Impala has a digital readout on the dash ,I want to retain my stock speedometer
2004 Extended cab LS silverado ![]() 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
What questions do you have? I just recently installed a 95 LT-1
1972 Blazer body...need to get a thread started for the rest of the story |
If you are dead set on keeping the original speedometer, you can do it one of two ways. There is a company that will take the electric signal from the VSS (vehicle speed sensor on the transmission), and convert it to a motor that will spin the cable for your original speedo. I think they were about $300 or so. Street and Performance has tailshaft kits to install a different tailshaft on the transmission (4l60e) so that you can plug your speedo cable into it like stock. It also has the VSS, so the computer will work properly. I just used an electronic speedometer for mine.
69 SWB LT1/4L60E www.classicplace.com |
chevelito
some good info here:
http://67-72chevytrucks.com/vboard/s...threadid=52057 do a search and some other things will pop up. jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
CCRider
Or you could take an electronic speedometer remove the needle, take the electronic part and mount it on an original face and install the original needle. Or you can get the box that minibike spoke of here:
http://www.transmissioncenter.net/sp...n_______va.htm
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Insert funny comment.
![]() Join Date: Dec 1999
Abbott makes a box caleld the Cable-X . It takes the digital signal from the tranny and spins a cable to drive the speedo. I ran one of these a few years in my Camaro and it worked great. They aren't cheap and have gone up about $50 since my purchase. When I purchased mine I was even able to talk the guy into an even lower price.
http://www.abbott-tach.com/cablex.htm
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
