Old 06-22-2018, 03:33 PM   #1
Baker72chevy
Stock Tachometer
How can you check tachometer to see if it works are not
Baker72chevy is offline   Reply With Quote
Old 06-22-2018, 09:44 PM   #2
lutronjim
Re: Stock Tachometer
If its mechanical, a drill and a old wooden match stick should make it register. Make sure it turns clockwise looking at the back.
lutronjim is offline   Reply With Quote
Old 06-22-2018, 09:47 PM   #3
Baker72chevy
It a stock out of a 71 c10
Old 06-23-2018, 06:51 AM   #4
custom10nut
custom10nut's Avatar
Just to check to see if it works, you can use test wires. Hook it to the coil and battery then start the engine. This won't allow to check accuracy, but it'll tell you if if works.
When I say accuracy, I just replced my original factory tach, because of the eradic reading. It would read low at idle, but high a cruise speeds.
They can be fixed, but a new one can be had for less than $100. I went new
custom10nut is offline   Reply With Quote
