Old 06-22-2018, 11:31 PM   #1
Cgaines78
Post Interchangeable parts from a 1980 to a 1969 Chevy
I have a 1980 Chevy I’m parting out an scrapping. My question is what parts if any are interchangeable with my 1969 . For my ‘69 I need a bench seat, A/C, P/S, Power Brakes an front disc brakes. All of which my 1980 has an cold easily swap over. Sorry for the dumb question but just got this 1969 project an it’s been 20 years since my last one.
Cgaines78 is offline   Reply With Quote
Old 06-23-2018, 12:11 AM   #2
supercheyenne
Re: Interchangeable parts from a 1980 to a 1969 Chevy
Easily is a relative term but MOST parts will swap.
The Disc brakes will swap. You will probably want to swap the rear end also because it would have the same 5 lug rotor/hubs. Your 1969 has 6 lug rotors.
Power steering should swap.
Bench seat should swap.
The A/C is NOT going to swap easily (if at all).
note: I'm not an expert on square body trucks (ie 1980). So some of my info might be wrong.
supercheyenne is offline   Reply With Quote
Old 06-23-2018, 08:35 AM   #3
Cgaines78
Old 06-23-2018, 08:37 AM   #4
Cgaines78
Thanks for the great info!! When you say P/S will does that mean the gearbox or just pump??
Old 06-23-2018, 09:34 AM   #5
raggedjim
raggedjim's Avatar
The gearbox and the pump should both swap easily.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 06-23-2018, 10:05 AM   #6
Cgaines78
Smile Re: Interchangeable parts from a 1980 to a 1969 Chevy
Originally Posted by raggedjim View Post
the gearbox and the pump should both swap easily.
Rg
thanks!!
Old 06-23-2018, 12:21 PM   #7
tutone
tutone's Avatar
Steering wheel, back glass maybe?, front xmember is a bolt in swap, seat if you change to your 69 brackets. Im sure there is more.
tutone is offline   Reply With Quote
Old 06-24-2018, 09:08 AM   #8
Mike C
Mike C's Avatar
The 69 has a short water pump and brackets, so if you use the 80 pump for the PS it will require the short pump brackets. And it MIGHT require the short pump reservoir as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-24-2018, 08:19 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
Brake booster swap. It "can" fit but you'll need a saw, welder, tape measure and a sharpie marker. Plus you need to learn how to cuss, swear and hold your tongue just right. I did it 14+ years ago and it's still going strong.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-24-2018, 08:32 PM   #10
Signkutter
So if I have a C20 72 2wd and the steering box leaks...what year of steering box would swap right in...any 73 to 80 3/4 ton?
Signkutter is offline   Reply With Quote
Old 06-25-2018, 11:20 AM   #11
volksworld
plenty of threads here on the disc swaps.. .30+ yrs ago i swapped in the entire front xmember for the brakes so a little fuzzy in the details....re-used the early center link ,box and idler and had to come up with a mix of tie rod parts to adapt to the square body spindles....but for all i know all the square body stuff would have fit, the x member just didnt come with them....think i had to modify the lower shock mount on the arm so it lined up better... again check the threads cause there are other ways to do this without putting in the whole xmember....i was lucky as my 70 used the same length rear axles as the later ones, but i believe your 69 had shorter axles (provided it still actually has its original rear...a lot can happen in over 40 yrs....just measure between the backing plates.... if one truck is coil spring and the other leaf you'll have to weld on perches and shock mounts to swap rears
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
