11-13-2003, 01:55 AM | #1 |
6-speed changeover
Does anyone have a step by step on the installation of a 6-speed into a 72? I'm curious at to the location of the shifter and what crossmember to use etc......
I'm new on this post, but get the impression that someone has done this and would like some feedback on the outcome......was it worth it, cost, etc....... Would love to see some pics! |
11-13-2003, 02:06 AM | #2 |
its all about the +6 inches
Crazy longhorn is the man to talk to on that.
Welcome to the board from Central Ohio |
11-13-2003, 03:17 AM | #3 |
Merciless Butcher
McCloud makes a really nice hydraulic clutch and hydraulic throughout bearing. Summit Has Them. It's a really easy way to go if you want to avoid linkage problems.
Your Bought And Sold....I Got Your Soul! |
11-13-2003, 04:14 AM | #4 |
Designated A-hole!
crazyl is the man to talk to.
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-13-2003, 04:15 AM | #5 |
Designated A-hole!
BTW we would love to see some pics of your truck.
11-13-2003, 01:26 PM | #6 |
I installed a 5 speed from a 96 Silverado. Had to----convert to hyd clutch, use auto crossmember, modify length of driveshaft, create clutch pedal linkage, move power brake assm forward a bit, convert to high hump and instll a new hole to accomidate 5speed, and figure out how to have a speedo as all the newer stuff use electronic sensed speedo--(Haven't figured out that yet!) so I use the tach for speed estimate.
I reduced the weight of the truck by at least 100lbs, improved the mpg by 4-5mpg, and increased the fun factor 3fold. Total cost about $1000. I do not believe you will be able to utilize the 6th gear very much unless you have a 373 or 411 rear end. A 308 or 342/354 rear will be way to tall for a 6th double overdrive gear. These truck have significant wind resistance over 60 and even my 5th gear with a decent 350 wants to lug going up steep hills or when towing with my 308 gear. If you are running a big block with real HP over 350HP, you may be abele to benefit from 6th. Good luck and e-mail me if you need more detail/pictures. Huck |
11-13-2003, 02:04 PM | #7 |
Wiseass secured himself a BAN
I wouldn't know anything about the change over.......... hmmmmm
11-13-2003, 02:54 PM | #8 |
T56 INSTALL
oh wait I HAVE made the change from a 3 speed on the tree to a after maket T56 6 speed. Your going to need: 1 a T56 modified so the shifter is in the most forward hole. 2. the adapter plate 3. 26 spline input shaft clutch plate ( 85 corvette is what I used from AutoZone ) 4. shorten your drive shaft ( I shortened mine 4 1/2 in ) 5. Fabricate a brace to hold the tail shaft of the transmission 6. Knock the floorboard up approx. 1in around critical clearance areas. 7. shifter if it doen't come with one 8 Fabricate a shifter stick to your liking. Any questions? Oh yeah I used the entire OEM bell housing, and clutch linkage with zero modifications. Here are some links http://www.sallee-chevrolet.com/BorgWarner/t56pics.html http://temp.corvetteforum.net/c3/gwhite75/install1.htm http://www.ttcautomotive.com/English...-0610-0199.pdf ( Service manual in PDF format ) Ben Last edited by 67Fleetsidedream; 11-13-2003 at 03:02 PM. |
11-13-2003, 03:06 PM | #9 |
Here are some pic for ya.
11-13-2003, 03:09 PM | #10 |
some more
11-13-2003, 03:10 PM | #11 |
dfh
11-13-2003, 03:14 PM | #12 |
here is the shifter location in the cab
11-13-2003, 06:43 PM | #13 |
Where in Sacramento?
Where are you in Sac.? I live over by Sunrise Mall. I have a '70 with my newly installed Caddy 500 c.i.d. motor.
11-13-2003, 09:39 PM | #14 | |
Re: Where in Sacramento?
72 swb Cheyenne "nut & bolt" frame off (in process) Blown 383 |
11-13-2003, 09:47 PM | #15 | |
Looks like you used the factory 3sp bell housing and clutch assembly. I don't have my original 3sp crossmember any more. wouldn't I be able to modify my auto crossmember for the t56 and use the hydraulic clutch setup.......pro's/con's. On a scale of 1-10.......was it worth the extra time, $$, and effort to do this? ....and also, I want to keep my 60/40 seat. will the shifter interfere? Thanks again!
11-14-2003, 01:25 AM | #16 |
Fabricate till you "puke"
the richmond 6spd also fits the stock bell, & is the same lenght within a fraction of an inch as a short tail 400 turbo....also takes the same slip yolk. There were no driveshaft mods to fit the richmond in my truck. The trans was installed on a modified auto crossmember, & uses factory clutch linkage(rod ends on the linkage for smoother operation). The shifter is right at the rear of the trans, & may interfere with a bench seat. the trans can b had in a 1 1/8 X 26, or 11/8 x 10 spline for the clutch. I run a centerforce dual friction clutch, on a Hays billet flywheel. The complete "mess" was not cheap, but sure is fun to drive! The Richmond is a close ratio box , with a low (3.28 to 1 1st gear), & would work very well with a 3.40 - 3.73 rear gear. O/D is .76, & that gives me a 3000 rpm cruise @ 80mph on the open road with 4.10's on a 28" tall tire. Sorry, I dont have any swap pics uploaded at this time. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-14-2003, 03:46 AM | #17 |
I read somewhere that Richmond or Long (the shifter manufacturer) can supply different shifter handles for different applications.
11-14-2003, 11:47 AM | #18 |
Yes, there ae different optional handles available. I the paperwork with my Richmond ther was part # & pics of the available handles. My sb sits in I 6 position, & I have Jazz buckets(no clearance issues). I did build my own shifter handle to fit. The long shifter comes with a very short , straight handle......crazyL
01-25-2004, 01:01 AM | #19 |
hey where has crazylonghorn gone? havent seen him since november
70 longbed 496/th400/Ford 9" |
01-25-2004, 01:45 AM | #20 |
I know, i been wondering that myself.
