Old 06-25-2018, 10:29 AM   #1
jasnake65
Wiper motor for 1960, its dead, need help
Took out my motor and looks like it died. Now i need a replacement, what has everyone one done? Its flat type, single speed.
jasnake65 is offline   Reply With Quote
Old 06-25-2018, 12:43 PM   #2
jbgroby
jbgroby's Avatar
Re: Wiper motor for 1960, its dead
Hi,
Did the upgrade and replacement to a new "Newport 2 speed wiper more. Find all the info you need here on the install in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=732838
jbgroby is offline   Reply With Quote
Old 06-25-2018, 07:50 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Id stick with the stock replacement. Its not as glamorous as a 2 speed
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-28-2018, 12:01 PM   #4
jasnake65
I broke down and bought a Newport, retro fit a new model or by a used one and hoping that lasts or buy a new one and be done and a quick install i'm hoping
Old 06-28-2018, 12:37 PM   #5
jbgroby
jbgroby's Avatar
The Newport motor went in as advertised, Simple straight forward bolt up to the 3 existing holes. My hands are big and I needed my wife to help hold and start the nuts in the cowl area. It took more time to disassemble the transmission arms and unbolt the old unit than it did to install the new unit and re-connect everything up. The motor comes mounted with the transmission bracket to bolt directly to the pivot bracket on the transmission shafts. (reuses your original nut).
The wiring it SUPER simple.
The unit has 4 wires, which connect directly to marked terminals on the switch. The power wire connects to your wire coming off the fuse block. Although they provide a black ground wire, the body the motor will serve as a ground as well (I CONECTED THE GROUND WIRE AS WELL)
Red (Power)
Blue (park)
Yellow (low speed)
White (high speed)
Black (Ground)
When you order, they will ask you if you wish to use the factory OWM dash knob or not. IF you choose to use your OEM knob, they will add a standoff shaft so you can install your original knob on the shaft. Fits like a glove in the original hole with the factory (D) slot.
