Old 11-13-2003, 02:18 AM   #1
crackajacka
Stylin
crackajacka's Avatar
blower motor problems narrowed down
ok i hooked the battery straight to the blower motor and it blows like no ones business. so i looked and the switch all it does is connect to that silverish module on the side of the a/c unit what is that called and how much is it to replace?
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 11-13-2003, 02:33 AM   #2
crossy
Oh,you can't buy that new
crossy's Avatar
generally it's the switch in the heat control thats bad . you can do a simple continuity check on that or just jump wire past it to see if 12V is coming that far. There is also a fat wire(orange?purple?) that runs to the blower motors for the high speed because that is almost direct. (no resistance) just passes through the switch. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 11-13-2003, 02:40 AM   #3
crackajacka
Stylin
are u talking about the one wire that plugs into the blower motor?
Old 11-13-2003, 03:08 AM   #4
crossy
crossy's Avatar
yes, it passes from the switch inside to a resistor bank for the lower speeds but high speed is direct. sometimes when the resistor block goes bad you will still have high speed. if the switch is bad you won't have anything. Check fuses? .DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 11-13-2003, 03:13 AM   #5
crackajacka
Stylin
well i had high for about 45 minutes then i had nothing
Old 11-13-2003, 03:29 AM   #6
crossy
crossy's Avatar
sounds like it took the fuse out at that point?
98 Vortec project.
94,3500,6.5L 4L80
Old 11-13-2003, 03:33 AM   #7
crackajacka
Stylin
all the fuses in the fuse panel are ok they are all new
Old 11-13-2003, 08:13 AM   #8
71-longbed
Its Magically Delicious
71-longbed's Avatar
after i put my new blower in ..it wouldnt work until i put a fuse in the air cond and the heater slot .... worth a try
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 11-13-2003, 10:57 PM   #9
jimfulco
The connector lugs on the blower relay (the little silver box) and on the resistor on my Sub are prone to corrosion, so every year I have to clean them (or at least wiggle them) before the heat will blow. The contacts inside the relay also are a bit finicky, & when they don't conduct, nothing blows. Sometimes a good thump on the cover will fix it for a while.
jimfulco is offline   Reply With Quote
Old 11-13-2003, 11:34 PM   #10
1985K10
1985K10's Avatar
My dads 98 Silverado lost everything but High. He changed the resistor block and it was cured...for a month or so, now only high works again.
If you have nothing at all id try bypassing the switch to see if its bad.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 11-14-2003, 10:26 PM   #11
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
i would have to disagree, its almost never the interior switch :/ in my experiences anyways..
but yeah its probably the relay thats giving you problems..
jimfulco hit the nail on the head when he said they are finicky and prone to corrosion.. The resistor tends to rust and then disintegrate also, so I would replace them both.. they're not expensive. If you still cant get it working, let us know and we'll get it straightened out, the circuit is really quite simple
mike
mike reeh is offline   Reply With Quote
Old 11-15-2003, 02:50 AM   #12
crackajacka
Stylin
ok whats do i need to ask for at the parts store when i go to get another resistor.
Old 11-15-2003, 06:09 AM   #13
mike reeh
mike reeh's Avatar
blower motor resistor and blower motor relay
mike
Old 11-15-2003, 11:28 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest you take your old one in and show it to them. That might save you a couple of trips.
Everytime I go to the parts store without the old part, I get to go back for the correct part. Sometimes twice...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-15-2003, 01:24 PM   #15
crossy
crossy's Avatar
Ken's right , even with the carb number in hand i was not able to come home with the right choke parts for my 85 the first time.
They have superceeded many part numbers into one more 'generic' number for old vehicles such as ours.. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 11-16-2003, 01:03 AM   #16
jimfulco
It just occurred to me that sometimes the function switch (heat, defrost, etc.) on mine has to be in exactly the right place for the fan to blow. Give everything a wiggle before you drop a bunch of cash.
Old 11-16-2003, 01:30 AM   #17
crackajacka
Stylin
well its the resistor thing, i can pull the plug then jump the connections with a piece of wire and select high,med,low,lowlow and connect 2 ports and it blows on that setting
Old 11-16-2003, 09:26 PM   #18
crackajacka
Stylin
still not blowing grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr, replaced the resistor and still nothing? what do i need to check next? n how
Old 11-18-2003, 02:12 AM   #19
apstguy
LED King
apstguy's Avatar
The blower switch. Have you used a multi-meter and checked all the wires?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 11-19-2003, 05:14 PM   #20
suburbasaurus
i dont know if i understand the problem here but the switch in the dash sends power to the high speed relay "little silver box on side of the a/c box" if you have power there the dash switch is good. the high speed relay is the problem if you jumped the curcits and it blows. you can get one at any parts store for $15 or less. we sell them at O'Reilly's for under $15.00. the problem with my burb was it wouldnt work on high. pulled one off another truck and it works fine now. good luck and hope this helps!
suburbasaurus is offline   Reply With Quote
