Old 06-25-2018, 01:15 PM   #1
Grizz1963
Grizz1963's Avatar
Retro fitment of modern seat belts to our cabs
Simple really, we know it gets done.
What is the feeling out there and and who,has fitted them, took photos and want to share please.
Advice on strength, fitting, welding and even sources of best options.
Thank you in advance.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 06-25-2018, 01:41 PM   #2
uk54
Re: Retro fitment of modern seat belts to our cabs
Hi Rian
Have a look at tips and tricks section at www.lugnutz65chevystepside.weebly.com shows everything you need for 3 point install, good to see you back working on your truck
Michael
uk54 is offline   Reply With Quote
Old 06-25-2018, 02:47 PM   #3
Grizz1963
Grizz1963's Avatar
Originally Posted by uk54 View Post
Hi Rian
Michael
This is excellent Michael, thank you.
Need to source a set of red belts now
Old 06-25-2018, 05:26 PM   #4
raidmagic
raidmagic's Avatar
Hi Rian
Michael
Great link and lots of good info, I'll be bookmarking your page. Question though, where did you get your belts?
raidmagic is offline   Reply With Quote
Old 06-25-2018, 05:53 PM   #5
gizmoduck81
Junior Member
gizmoduck81's Avatar
I installed two 3-point (driver,passenger) and one lap belt (center) in my '63 and they work great. I don't have any pictures of them installed unfortunately and everything is torn back apart now. I did not weld them as the kit I bought is bolt in with proper backing plates. My belts were ordered from Julianos. They have a ton of colors and options.
Edit: I used the 90 degree bracket for the driver side, but I had to order a 60 degree bracket from Jegs for the passenger side floor mount.
gizmoduck81 is offline   Reply With Quote
Old 06-26-2018, 03:27 AM   #6
Grizz1963
Grizz1963's Avatar
A reply that was posted on another forum I use.
If it I still a problem, for them to post to the USA, I could beep by being a UK delivery address.
Ebay link
https://www.ebay.co.uk/itm/RED-Unive...19.m1438.l2649
Old 06-26-2018, 06:26 AM   #7
PGSigns
PGSigns's Avatar
I used these guys when I did the three point install in mine. Have held up great and work well over time. http://www.andoauto.com/
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-26-2018, 11:02 AM   #8
66K20
66K20's Avatar
Jimmy
I installed a new set of Andover lap belts in my 66 last night. While I did not use a modern 3point belt, I can say the belts were beautifully crafted. There was no loose stitching on the webbing and the end of the webbing was 'finished'. I would not hesitate to buy from Andover again
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
Old 06-26-2018, 12:10 PM   #9
Jackson's Dad 64 C10
Jackson's Dad 64 C10's Avatar
I used belts from https://www.seatbeltplanet.com/ when I had my '65 Nova. They were really knowledgeable, and very easy to deal with. There wasn't a specific kit available for that car, so I just gave them a call, and they took care of everything. The price was pretty reasonable too.
-Chris
Jackson's Dad 64 C10 is offline   Reply With Quote
Old 06-26-2018, 05:59 PM   #10
Cris
Anybody use these guys?
http://www.buckle-up.net/id12.html
Cris is offline   Reply With Quote
Old 06-26-2018, 10:07 PM   #11
AcampoDave
AcampoDave's Avatar
I too give a thumbs up to Juliano's. The mount plates for under the floor and inside the pillar were first rate.
AcampoDave is offline   Reply With Quote
Old 06-30-2018, 06:46 PM   #12
Heater63
Heater63's Avatar
Me too; I think theirs are a step up from seatbelt planet.
Good advice above from everyone. This is an easy upgrade I highly recommend you do!
292 + TKO500
Heater63 is offline   Reply With Quote
Old 06-30-2018, 06:50 PM   #13
Heater63
Heater63's Avatar
A little torch heat and you can bend the 90 to a 60 for the passenger side.
292 + TKO500
Old 07-07-2018, 11:06 PM   #14
vince1
I got as far as drilling the holes and installing the nuts up in the cab corners. Then I decided the seat had to go and the replacement had the built in belts.
vince1 is offline   Reply With Quote
