Old 06-27-2018, 05:19 PM   #1
JackB
AC Belt Alignment problem stock 350
I have a problem with the belt alignment on my stock 350 motor . All the brackets are stock original sbc parts but the AC compressor is off by one groove. Basically it wants to line up with the crank/water pump groove already being used by the alternator. Any ideas what my problem is? Wrong clutch on the compressor maybe? Should the compressor mount in front of the adjusting bracket and not the back?
JackB is offline   Reply With Quote
Old 06-27-2018, 06:09 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: AC Belt Alignment problem stock 350
Move the compressor forward of the bracket.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-27-2018, 06:37 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Your compressor is mounted correctly on the top bracket (it goes behind it). It goes in front of the lower circular shaped bracket. I can’t tell from the pic if yours is mounted correctly on that bracket. From the top pic it looks like it’s behind the circular bracket...it should be sandwiched between them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-27-2018, 07:18 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ This.
Easier to see the brackets in this pic. The big cast (gray) bracket bolts to the engine. The black circular bracket bolts in front of the cast bracket, as shown in the pic.
Then your compressor bolts in front of the circular plate. Finally, the slotted top bracket goes in front of the compressor as shown in your pic.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-27-2018, 07:42 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Found one more pic that might help.
- Mike -
RIP El Jay
Old 06-28-2018, 12:00 AM   #6
JackB
Thanks guys the pics helped a bunch and its all together. One thing I did run across is the electric connection is very close to the bracket. So close that I had to bend the prongs out to get the connector on. I think I read someone else had this issue as well the original compressors had the electrical connection somewhere around the 11 O'clock position and at least some of the remans are more like 1 or 2 O'clock. At any rate I think its going to be OK.
Old 06-28-2018, 12:45 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If it's an issue, the front of the compressor can be re-clocked to place the connector in a better location. I just had a new reman compressor installed and the connector was in a bad spot. The shop was able to re-clock it.
- Mike -
RIP El Jay
Old 06-29-2018, 04:26 AM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
I have Know idea why you cut the shroud. the ones on my 1971 dose not show you have to
stsalvage is offline   Reply With Quote
Old 06-29-2018, 04:31 AM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
More pics of the 1971 1/2 ton chevy truck
Old 06-29-2018, 04:33 AM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
More stuff on the AC of what you need
Old 06-30-2018, 07:33 PM   #11
JackB
Thanks again guys..AC is hooked up and functioning...The pictures were a great help.
