Old 06-30-2018, 03:24 PM   #1
dave`12
dave`12's Avatar
Making a fleetside into a short bed
I have a line one a pretty good 67 short bed (bed only). I have the fleetside.
Does anyone know how much trouble it would be to convert it? Is the wheelbase the same?
dave`12 is offline   Reply With Quote
Old 06-30-2018, 04:32 PM   #2
franken
Re: Making a fleetside into a short bed
Fleetside and stepside are styles, not lengths. Either can be short or long. If you currently have a longbed, then a shortbed will require cutting or replacing the frame.
franken is offline   Reply With Quote
Old 06-30-2018, 05:16 PM   #3
dave`12
dave`12's Avatar
I realized that, and came back to fix the post. Sorry. I have the long bed and want to change it to a short bed. Both fleet side.
I don't mind cutting the frame if the wheel base is good!
Old 06-30-2018, 06:27 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Follow the instructions in this thread.....
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
LockDoc
Leon
Old 07-01-2018, 06:40 AM   #5
The wheelbase won't be good. This is where a LWB and a SWB vary, in the WB. You definitely will be cutting the frame
Old 07-01-2018, 08:15 AM   #6
dave`12
dave`12's Avatar
Thanx. I figured as much. Too much for me. I'm out.
Old 07-01-2018, 05:15 PM   #7
rockyrivermark
It's very easy to do with you have moderate skills and tools.
Check out this video
Brothers kit makes it very easy.
You take 12" out of frame under bed and 8" off the end of the frame Weld frame yourself o have a muffler shop do it.
Have shop cut, weld and balance driveshaft 12" shorter
New rear brake lines, shorten fuel line. Etc.
https://m.youtube.com/watch?v=uSkcJsgCW68
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 07-01-2018, 05:42 PM   #8
rockyrivermark
In fact an episode of truck U doing a short bed conversion on a mid 60's C10 right now.
Same process.
Google that episode.
My build page
