Old 07-01-2018, 02:16 AM   #1
fredhlynch2
Tilt Bed Floor
Working on my tilt bed. Thinking about using gas struts but need to figure out the weight to use the right shocks. Will be adding wood and bed strips so it looks stock
fredhlynch2 is offline   Reply With Quote
Old 07-02-2018, 05:44 PM   #2
Bentbolt
Re: Tilt Bed Floor
it looks really nice. its gonna be fairly heavy (25#) once you add the wood I'm sure. I'm planning on doing something along this to mine but I'm not sure if I want the whole section to lift. been searching google for other options of what other people have done.
Bentbolt is offline   Reply With Quote
Old 07-02-2018, 05:51 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Tilt Bed Floor
Hard to just guess at.... mounting location can change the poundage of the needed cylinders...the closer to the hinge point the stronger they'll need to be...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-02-2018, 06:01 PM   #4
Lil Loafer
Re: Tilt Bed Floor
That looks great. I want to do something like this on my 66. I saw where someone did something similar to this but used air shocks instead of gas struts, so it had no problem holding the weight. The only problem is it did not lift very high.
Lil Loafer is offline   Reply With Quote
Old 07-03-2018, 08:55 AM   #5
fredhlynch2
Re: Tilt Bed Floor
I did some checking and it appears electric (12V DC) linear actuators may be the way to go. Come in all sizes (lengths up to 30") and can lift up to 250lbs lift capacity. Run off a single toggle switch for up or down. Best part is they are cheap...Ebay, Amazon, Dakota digital and others.
Old 07-03-2018, 10:55 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Tilt Bed Floor
I have a tilt bed in my '66, but its the rear 1/2 only. I run a pair of 35lb gas struts. If I were running air ride, I would just tap the tank and run Bimba cylinders.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-17-2018, 05:53 PM   #7
tdishon
Re: Tilt Bed Floor
This is what I've been looking for. Where did you get the hinges?
Current project: 59 Apache with 2012 Corvette drivetrain
Jeep Trackhawk(beast)
tdishon is offline   Reply With Quote
Old 08-19-2018, 12:15 AM   #8
fredhlynch2
Re: Tilt Bed Floor
Here is the place I got the hinges.
They sell two versions. I went with the heavy duty.
There might be other vendors.
http://www.sachserodshop.com/newproducts.html
