07-01-2018, 10:36 PM | #1 |
Are 2.73 gears hard to find?
Hey guys, poked around the site and finally registered to get some info I couldn’t find searching.
I have a 68 c10 with 250 and 3 speed and an open, I’m told they came with 3.73 gears but I’m not sure (they’re likely stock based on the rest of the truck). I’m looking for a high gear set for a big block swap but 3.08 is the best I could find. It looks likely they made a series 2 carrier, is that hard to find? I couldn’t find any info for 67-72 trucks. If I have a series 3 I “should” be able to run a used set of 2.73 gears. Are they only square body c10’s? A used set of gears and a series 3 posi and I should be all set? After looking through craigslist, the classifieds and eBay I didn’t see a lot of options, are they in demand, or is it one of those things guys don’t really sell because there isn’t a market? Going with big block/auto and want to keep the trans I have. Thanks for any info, Arden Last edited by Ardenq; 07-01-2018 at 10:49 PM. |
07-01-2018, 11:00 PM | #2 |
Re: Are 2.73 gears hard to find?
They were really only late 70’s. Early 80’s when they switched to the 10 bolt you get 2.41 or 2.56 gears.
I just sold a ‘78 Blazer that had 2.73 gears in it. They are not common and NOT in demand!
07-02-2018, 12:15 AM | #3 |
I have a 350/th350/3.08/28" tires and I can't see going to 2.73 gears even with 27" tires.
I can do 90 down the freeway without the engine screaming. Just grab a 3.07 readily available rear axle and be done. |
07-02-2018, 08:32 AM | #4 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by LockDoc; 07-02-2018 at 09:16 AM. Reason: FS by non premium member |
07-02-2018, 09:59 AM | #5 | |
Yeah I’m in Austin, I appreciate the offer but I’m going to hold out a little bit and try to find a set of 2.73’s. Do you know if my six cylinder three on the tree should have a series three carrier?
07-02-2018, 05:10 PM | #6 |
I think there was someone in the driveline area was asking about swapping 3.73 for their 2.73 and limited slip
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
07-02-2018, 05:21 PM | #7 |
had a stock 88 1/2 ton with 2.73 it was a 12 bolt rear, maybe look for one of them as a donor
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
07-02-2018, 10:18 PM | #8 | |
Post Whore
GM is pretty smart so there was a reason they didn't offer 2:73's with the stock power trains. Are you running significantly shorter wheels and tires than stock? Remember that when you install taller gears that the load on the engine is increased and it has to work harder to do the same work. If you are trying to gain fuel economy you may end up burning more fuel as the engine will not be running in its most efficient power band. Keeping the 3:73's and getting an overdrive is more expensive but may be better in the long run. Just my opinion and by no means the last word on the subject.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-02-2018, 10:22 PM | #9 |
The carrier break for a truck is 2.73 and down. The 3 series is 2.76 to 3.42 and the 4 series is 3.73 and up. So if you have 3.73 you have the 4 series carrier. If you want to run the 2.73 you will need a 2 series carrier. If you can find the 2.76 you can run a 3 series carrier.
The Blazer I just flipped was actually 2.76 geared. It was a 4x4 78 originally TH350/NP203 with a 400 small block.
