07-02-2018, 12:39 PM | #1 |
1960 GMC Burb
1969 Burb Bell Housing mounts
So I got the engine back in and was able to change from the 4-on the floor back to the original 3-on the tree. I wasn't there when the engine was pulled and now I am trying to find out if something is missing. The two rubber bell housing mounts appear to be missing possibly a another side of rubber ?
Can anybody tell me what is missing from these mounts?
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
07-02-2018, 08:58 PM | #2 |
Re: 1969 Burb Bell Housing mounts
MusicMan70 1961 GMC Suburban |
07-03-2018, 10:30 AM | #3 |
Never Ending Projects
Yes, those are the lower half of the mounts, that will slide into the crossmember. You need the upper half, which are U shaped that ride between the bell housing and the crossmember. Also verify that the bolts are the correct size for the bell housing, as it seems there are two different thread sizes used. Easier to verify while out of the vehicle.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-03-2018, 07:13 PM | #4 |
1960 GMC Burb
Thank you for your responses. MusicMan THANK YOU ! it was right on.NAPA part number 602-1034 I paid $6.49 each.
Thanks to Corts60 for posting it originally.
