Old 07-02-2018, 04:40 PM   #1
crsgmc
Spark Plug Looms
I have spent a fair amount of time trying to find the factory spark plug dividers with no luck. I would just like to buy the plastic parts but would also buy the factory bracket. I have attached a picture of the drivers side rear bracket. You will notice that one of them is for three wires, this was replaced by someone in the past. This should be a two wire bracket. The other clip shown is missing the top closure. This is for a 1996 GMC K1500. The bracket mounts to the head below the valve cover. I would think that someone would make these plastic brackets. One of the currently available new GM crate engines uses the same bracket. Thanks for any help you can provide.
crsgmc is offline   Reply With Quote
