Old 07-04-2018, 02:44 PM   #1
Driver_WT
Driver_WT's Avatar
S10 Brake Proportioning Valve Lines
My AD truck is sitting on a 1993 S10 chassis. I am just starting to plumb the brake lines, there are no brake lines currently on the truck. The 1993 S10 brake proportioning valve has two lines going in the top (input lines from master cylinder) and then two output lines - a 1/4" brake line to the rear brakes and a 3/16" brake line for the front brakes. Based on pics that I have found, I was expecting the brake proportioning valve to have two output lines to the front brakes, but mine has only one. Can I just put a 3/16" tee in the front brake output lines and then run a 3/16" line to each front brake caliper?
Thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 07-04-2018, 03:47 PM   #2
1project2many
Re: S10 Brake Proportioning Valve Lines
Many vehicles built before ABS have a single line to the left front then Tee off to the wheels.
1project2many is offline   Reply With Quote
Old 07-04-2018, 04:42 PM   #3
joedoh
joedoh's Avatar
Thanks.
Wade
the factory tee is usually on the drivers frame/engine on s10s, so yes, as 1project says, a tee will be fine
on abs equipped trucks there is no tee, just separate left right outputs
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-05-2018, 05:19 AM   #4
Driver_WT
Driver_WT's Avatar
Thanks guys. I appreciate the help.
Wade
