gas cap question
I have searched but no luck. NEED VENTED GAS CAP FOR 72 C10 WITH STOCK GAS TANK. anybody have the answer? THANKS
Re: gas cap question
maybe I should explain more. truck has had a 5.3 swap. vent line on tank was used for return line. now I need to vent tank. 71-72 fuel caps are non vented. 67-70 are vented but the filler neck on tank is bigger so those caps wont fit my tank. has anybody else had this problem? how did you fix it?
![]() Join Date: Jul 2009
Check out a 1972 c20 or c30 gas cap. The 3/4 ton and larger trucks were available without the emissions package and had vented caps.
just went out and checked a c20 calls for stant 10623. it will not fit my c10.
| Bookmarks |
