![]() Join Date: Aug 2017
Need Help! Extra parts
I have a 1970 C20 that I am trying to restore as original as possible. I was replacing a damaged exhaust manifold and got carried away cleaning, painting, and at times replacing every imperfect part I could now reach and/or see. I tried to take good photos as I dismantled the left side of the original 350, but didn't do it well enough. There is a single green wire that was in original loom that ran through the clips affixed to the top of the left valve cover. It was not attached to anything as it came our toward the front of the engine compartment. there were two clips with bolt holes that this wire and loom were running through. I can't remember where they should go and don't know what this wire should be connected to. Any help would be greatly appreciated! I've attached photos that I hope will help.
![]() Join Date: Mar 2003
Re: Need Help! Extra parts
Green wire goes to the sending unit in the side of the head between number 1 and 3
Thank you so much. I have a wire I removed from the sending unit. The previous owner must have rerouted it; therefore, I'll chase that one down and make sure it's done right. Any idea where those two clips go?
