did our year of trucks come with a 10" clutch
I'm sure my engine is stock and has a 10" clutch, but I was just told different. A guy at another parts store I just called, told me that the inline 6 in a full size half ton used 11" clutches, not 10. Can anyone comfirm that a 10" clutch is in fact stock in these trucks
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Wiseass secured himself a BAN
I had the 327-3 on the tree in my truck and it came factory with a 11in clutch with a 12in flywheel. I wouldn't think that it would be different if the engine was a I6.
Just replaced my stock 10 in clutch in a 70 C10 6cyl 3spd.Napa told me 10 in cost more because everyone replaces them with 11 in.Mike
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
Stock clutch is 10" 11" was a Heavy duty option on small V8, and standard with most 4 speeds. If the flywheel is big enough, and drilled for the 11" put it in. You will never regret it!!
69 GMC K10 ..some restoration required....still.. ![]() |
Not the nightly winner
i checked mine today and its a 10 inch
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
my stocker was a 10 also, replaced it with a new 10" and it lasted about a month and fell apart, replaced it with an 11", no more troubles after that.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
I need another Barley Pop
Not sure what mine came with originally, but I would guess that it was an 11". When I recently replaced my clutch, my parts guy pulled an 11" and had it sitting on the counter when I went to pick up the new parts. However, when someone did the big block swap in my truck, they put a 12" setup in it. I'm happy with the 12".
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
70 Chevy 3/4t
when I rebuilt my I6 I replaced the clutch beings it was open and accessable. It was an 11".
Find a job you love and you'll never have to work a day in your life. 1998 Yamaha V-Star 650 1970 Chevy 3/4t, I6 (rebuilt), 4 speed Kokomo,IN |
![]() Join Date: Feb 2002
My '68 C/10 stepside came optioned w/292 L6, SM465 4-speed and 11" clutch.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-14-2003 at 05:46 AM. |
I know the standard clutch for a 250 is 10". My 70 C-10 with a 250 came with the heavy duty clutch option which is 11" for a 250. I was under the impression that V-8's came standard with an 11" clutch and a heavy duty clutch was a 12". As noted above if you have an 11" clutch you can upgrade to a 12" using the same flywheel. Hollanders only shows one flywheel for V-8 applications which is the 11"/12" clutch. The V-8 flywheel (used on most Chevy truck and cars to about 1985) is the same one used on the 250 with heavy duty (11") clutch.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
My old 71 with a 307/4-speed was 11", my 72 Blazer/4-speed is a 11", and my 70 GMC was a 11" all were factory. In 1993 I bought a lifetime warranty clutch from a national parts chain and have used the same receipt for all my trucks. They have all been the same 11 inch clutch.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
FINALLY found a 10" clutch kit. I swear to god that it must be a bastard clutch size up here.
I have a clutch kit on it way over night to me, so I can install it tomorrow morning. I am using a replacement 10" to put on my 350, since it's just a summer cruising truck, i don't need anything heavy duty. Oh and it's cost me $50 less than the 11" that I was sold
