Old 11-13-2003, 07:41 PM   #1
ChevyDude
Angry Help...broke a freakin spring>>>>
I was swapping out my 31 year old accelerator pedal and the freakin spring snapped when I went to take it off. Can someone tell me where I can get another on of these gas peadl springs... it's a 72'.
Thanks,
Alex
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-13-2003, 07:50 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
go to your local hardware store or your local auto parts store.
Take the spring with you and tell them that you need one.
67Fleetsidedream is offline   Reply With Quote
Old 11-13-2003, 08:04 PM   #3
Sweet72
Sweet72's Avatar
Same thing happened to mine, luckily I found some in a junk yard. I suppose you could make one from some really thin music wire from a craft store. Just anneal it and bend around a makeshift mandrel, then re-harden by very carefully heating it cherry red, and quench in warm water.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-13-2003, 09:07 PM   #4
Class of 69
Class of 69's Avatar
Auto parts stores sell auto parts...even throttle return springs.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 11-13-2003, 09:11 PM   #5
Sweet72
Sweet72's Avatar
ChevyDude, you're referring to the small spring that is unique to the 71 and 72 trucks on the pedal itself right? Not the throttle return spring.
Old 11-13-2003, 10:58 PM   #6
ChevyDude
I am refering to the little spring that holds the accelerator pedal upright. A little pin goes through the spring and the pedal and then this little spring wraps onto the post that the pedal is attached to.
Alex
Old 11-13-2003, 11:02 PM   #7
dtlilly
dtlilly's Avatar
Napa usually has a good selection of odds and ends like that, or try a hardware store.
dtlilly is offline   Reply With Quote
Old 11-14-2003, 12:38 AM   #8
junkyardjohn
junkyardjohn's Avatar
THAT IS NOT AN ORDINARY SPRING THAT YOU CAN PICK UP AT ANY HARDWARE OR OUTO PARTS STORE. (AS IF YOU DIDN'T KNOW THAT ALREADY) IT'S CALLED A PEDAL RETURN SPRING. I HAVE AN LMC CATALOG HERE HANDY & IT'S PT.#30-3194 & IT'S $2.55 . I'M SURE ALL THE VENDERS HAVE EM. THEY'RE ON 71 & 72s. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-14-2003, 01:14 AM   #9
dtlilly
dtlilly's Avatar
Heck, I'd use a bungie cord if that is what it takes to get down the road. I really didn't know that those springs were reproduced, but thanks to a board member, several of us learn something new
Old 11-14-2003, 05:24 PM   #10
ChevyDude
A big Thanks goes out to JunkYardJohn!!! He directed me to LMC Truck parts who did have it for $4.99 + $6.00 shipping.... but then I called GMC Paul's who told me to try my local Chevy dealer.....and wah da ya know.... Part # 368077 known as Accelerator Tension Spring was in stock and ready for me to pick up for $4.11 + tax or $4.43 out the door. I went and got it and she's in the truck now!!! Don't worry if the dealer tells you that part #368077 is for an 82' Vette, it is, but it was originally used on 71's and 72 C-10's and K-10's. Thanks again!!!
Alex
Old 11-14-2003, 05:33 PM   #11
Class of 69
Hats off to Junkyardjohn, again.
Sorry for assuming it was the throttle return spring...I should read posts more s l o w l y and carefully, I would have seen that. You know what you get for ass-u-ming.
Old 11-14-2003, 05:43 PM   #12
junkyardjohn
EVEN A BLIND SQUIRREL FINDS A FEW NUTS
junkyardjohn
DON'T RENT U-HAUL
Old 11-14-2003, 06:39 PM   #13
67Fleetsidedream
So next time before you blow a fuse and ask where to get one you will call the dealerships parts counter first. A lesson learned.
Old 11-14-2003, 07:44 PM   #14
ChevyDude
I hope you are not implying I was blowing a fuse??? I never would have guessed the dealers would have this and simply asked the board if anyone knew where to find one.
Now everyone knows.
Alex
Old 11-14-2003, 08:20 PM   #15
junkyardjohn
GEEZE FLEETSIDEDREAM -- WHAT HAVE YOU GOT A BUG UP YOUR @SS ABOUT??. THERES NOTHING WRONG WITH ASKING QUESTIONS. THATS HOW WE ALL LEARN. AT LEAST HE DIDN'T LISTEN TO YOUR INCORRECT ADVICE & GO RUNNING OFF TO A HARDWARE OR AUTOPARTS STORE. .
I HOPE YOU LEARNED A LESSON ABOUT GIVING ADVICE ON SOMETHING YOU APPARENTLY NO NOTHING ABOUT
junkyardjohn
DON'T RENT U-HAUL
Old 11-14-2003, 08:39 PM   #16
cdowns
cdowns's Avatar
awww screw that i like the bungie cord idea
Old 11-14-2003, 08:49 PM   #17
67Fleetsidedream
no bugs here
Actually the hardware store or the auto parts store would have had a spring that would work just fine.
Go eat some mash potatos and take a PROZAC junkyardjohn
Your always right------------ GOOD FOR YOU
Get yourself a screw driver and pop the caps lock button of your keyboard.
Old 11-14-2003, 09:01 PM   #18
junkyardjohn
[QUOTE]Originally posted by 67Fleetsidedream
[B]no bugs here
Actually the hardware store or the auto parts store would have had a spring that would work just fine. [QUOTE]
I GUESS YOU STILL DON'T KNOW WHAT THE SPRING HE WAS LOOKING FOR LOOKS LIKE.
GREAT ADVICE & SUPER INTELEGENT DIALOG:p :p
junkyardjohn
DON'T RENT U-HAUL
Old 11-14-2003, 09:03 PM   #19
67Fleetsidedream
Old 11-14-2003, 10:17 PM   #20
71Chev
71Chev's Avatar
Here's the 71-72 pedal return spring.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 11-14-2003, 11:08 PM   #21
junkyardjohn
THANKS LES
junkyardjohn
DON'T RENT U-HAUL
Old 11-15-2003, 07:54 AM   #22
ChevyDude
That is indeed the spring. I've got to go to get anti-freeze from the Auto Zone..... I will ask if they carry such a spring...just for grins.
Thanks for posting the pic!
Alex
