Old 07-07-2018, 01:53 AM   #1
QBRacing
58 Fleetside, removing light & rear tray lower panels...
Today I decided to try and remove the rear taillight panel and the rear lower panel of the 58 Apaches wellside (see attached).
I wanted to remove the light panel to see if i could fix it as it has been dumped on its corner and is bent out of shape. I also wanted to clean up the lower panel and put some Por15 on the inside etc to help make it last a little longer...
I undid the bolts in the lower rear corners (where it attaches to the inner panel) but then I saw some welds. With these welds i cant see how to seperate the rear panel or the tail section....
are the welds normal and is so what the hells the point of the bolts....
QBRacing is offline   Reply With Quote
Old 07-07-2018, 11:57 AM   #2
_Ogre
_Ogre's Avatar
Re: 58 Fleetside, removing light & rear tray lower panels...
fleet or step side trucks were bolted together,then welded to reinforce the rear pocket at the tailgate
shop air compressor timer
Old 07-07-2018, 02:58 PM   #3
Foot Stomper
Foot Stomper's Avatar
Yup, ran into the same thing when taking apart my 59 Fleetside. Boggles my mind how they thought it needed welding.
It went back together with bolts only.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 07-08-2018, 07:44 AM   #4
hogfarm
Looks to me that your bed has some extra not factory welds
hogfarm is offline   Reply With Quote
Old 07-09-2018, 11:06 PM   #5
buggy5872
buggy5872's Avatar
They did not come from the factory welded. Someone added it.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 07-09-2018, 11:14 PM   #6
QBRacing
thanks for the replies.
I ended up applying the POR to the top while in place then using a rubberized underbody spray to hit the underside of the channel.
thought it was weird
Old 07-10-2018, 12:19 AM   #7
Foot Stomper
They were welded in the factory. Definitely.
Old 07-10-2018, 11:36 AM   #8
_Ogre
_Ogre's Avatar
fam sec 1 sheet 135 detail m-m
shows 2 welds with instructions to 'weld stake pocket to rear cross sill'
Old 07-10-2018, 11:52 AM   #9
MARTINSR
MARTINSR's Avatar
The AD beds were welded like that too, along with bolts. And only on the rear threshold. You can see the bolts and the welds looking right near the tailgate hinges. And that's it, a weld on each side, the rest of the bed is bolted together, kinda funny.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-10-2018, 04:55 PM   #10
Russell Ashley
Russell Ashley's Avatar
You have to remember that these trucks were meant to be "beasts of burden" and not loved on like most of us do our trucks now. The bed sides would never have stayed at right angles to the bed floor if they weren't welded.
Russell Ashley is offline   Reply With Quote
Old 07-10-2018, 04:59 PM   #11
_Ogre
_Ogre's Avatar
i beat the crap out of my longbed 09 gmc, not loved obviously and it shows
