Old 11-13-2003, 08:13 PM   #1
406cid70Chevy
Can someone tell me the names of these seals?
here's the pic. I don't know the names, so it's kinda hard to get new ones. It's a TH400 Tranny. Thanks for any help.
406cid70Chevy is offline   Reply With Quote
Old 11-13-2003, 08:32 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Here is what I do when I don't know a name to a part. I take the part off the truck and go to the parts store or the Chevy dealerships parts counter. Show them the parts that I need and see if the can provide. Usually they can fix you up.
Hope this helps
67Fleetsidedream is offline   Reply With Quote
Old 11-13-2003, 08:38 PM   #3
Class of 69
Class of 69's Avatar
#1 is an adaptor. You may be able to get a replacement gasket from a speedometer, or transmission shop.
#2 is the speedometer driven gear sleeve. It takes an O ring. Also available at the transmission shop, or a GM dealer.
I suggest replacing the driven gear itself while you have it apart. If you have trans fluid leaking out of the adaptor, it is following the gear shaft thru the sleeve, and should not do that. I suspect the shaft on the driven gear is very worn. They are just plastic, and color coded for replacement.
When replaceing the gasket in the adaptor, it should actually be packed with grease. You may consider just taking the adaptor to a speedometer shop. They can set up a complete replacement unit at a low cost, or clean, inspect, pack, and replace the gasket for you.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 11-13-2003, 11:57 PM   #4
406cid70Chevy
Ok thanks guys, you're a big help.
Old 11-16-2003, 10:53 PM   #5
72superBB
72superBB's Avatar
I just replaced this on my th400. I replaced the #2 part of your picture. It isthe speedometer gear housing. The Gm dealership said to get the o ring inside I hade to buy the whole housing which was around $45. The speedometer gear was replaced as well (this was only$6) because it was worn around where the seal rubbed. I did not replace part #1 because they told me that fluid should never be past part #2. So if you replace the speedometer gear and gear housing(which comes with a new o-ring) then you should be fine with the part #1 you have.
hope this helps.
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 11-17-2003, 01:10 AM   #6
walker
walker's Avatar
The one on the left is Fred, the one on the right is Joe. Hope this helps, at least you can call them by name when you're cursin at 'em for leakin'
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 11-17-2003, 03:11 AM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
Wow, good question. Thats what make this board so great. Sharing the knowledge.
jugernot is offline   Reply With Quote
