07-08-2018, 10:36 AM | #1 |
BlahBlahBlah
Shortening brake lines?
I'm scrapping some chassis and wondering if the brake lines are worth keeping. Can you shorten brake lines by cutting, flaring and putting in a brass junction? Heck of a lot cheaper to reuse perfectly good parts than to be continually buying new stuff. And you know it's going to fit
07-08-2018, 10:48 AM | #2 |
Proprietor of Dale's Corner
Re: Shortening brake lines?
I've done it.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-08-2018, 11:10 AM | #3 |
Post Whore
The problem with brake lines is they rust from the inside too. Brake fluid absorbs moisture from the air until saturated and over time it drops out and the steel factory lines began rusting. That one reason why it is recommended that brake fluid is replaced regularly. So old lines may be fine until that time you really hammer the brakes and that rusted spot you can't see fails.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-08-2018, 02:01 PM | #4 | |
07-08-2018, 02:17 PM | #5 | |
07-08-2018, 02:39 PM | #6 |
BlahBlahBlah
Sounds like they aren’t worth saving then. I’ll just leave em attached to the chassis for the scrapper.
