Old 07-08-2018, 11:50 AM   #1
Bennett68C10
Bennett68C10's Avatar
Porterbuilt Gas Assist Hood Hinges & Pro Performance Carrier Bearing Spacer
New in box, Porterbuilt Gas Assisted Hood Hinges for 67-72 trucks! Never installed, left over from a previous project!
SOLD
Pro Performance carrier bearing spacer for 2 piece driveshaft on trucks that lay frame! Brand new, left over from a previous project! Click the link below for specs!
http://www.azproperformance.com/Alum...C10-32150.html
SOLD
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-08-2018, 08:16 PM   #2
1968c
Re: Porterbuilt Gas Assist Hood Hinges & Pro Performance Carrier Bearing Spacer
I will take it. Need your paypal information
1968c is offline   Reply With Quote
Old 07-08-2018, 08:24 PM   #3
Bennett68C10
Do you want both items? I’ll pm you PayPal info!
Keith
66 Suburban
IG: bennett68c10
Old 07-09-2018, 07:59 AM   #4
1968c
Just the hinge
Old 07-09-2018, 08:09 AM   #5
Bennett68C10
Porterbuilt Hood Hinges sold to 1968c pending payment!
Keith
66 Suburban
IG: bennett68c10
Old 07-10-2018, 08:09 AM   #6
1968c
payment sent
Old 07-10-2018, 08:54 AM   #7
Bennett68C10
payment sent
Thanks, I will get them shipped out this afternoon!
Keith
66 Suburban
IG: bennett68c10
Old 07-10-2018, 08:55 AM   #8
Bennett68C10
I still have the carrier bearing spacer if someone needs it!
Keith
66 Suburban
IG: bennett68c10
Old 09-06-2018, 10:48 AM   #9
Hart_Rod
Hart_Rod's Avatar
Still available?
Hart_Rod is offline   Reply With Quote
Old 09-06-2018, 06:26 PM   #10
Bennett68C10
Originally Posted by Hart_Rod View Post
Still available?
Yes sir, I still have it
Keith
66 Suburban
IG: bennett68c10
Old 09-06-2018, 08:05 PM   #11
Hart_Rod
Hart_Rod's Avatar
How tall is it?
Old 09-06-2018, 08:47 PM   #12
Bennett68C10
It’s 2.5” tall and includes shims to raise it up an additional 3/4” if needed.
Keith
66 Suburban
IG: bennett68c10
Old 09-06-2018, 09:05 PM   #13
Hart_Rod
Hart_Rod's Avatar
Will it work with this crossmember?
Old 09-06-2018, 09:12 PM   #14
Bennett68C10
If you can get me some measurements from bolt hole to bolt hole and total width of the center mounting area I can measure the spacer for you.
Keith
66 Suburban
IG: bennett68c10
Old 09-07-2018, 06:27 AM   #15
Hart_Rod
Hart_Rod's Avatar
If you can post the dimensions of the spacer, I'll see if it will work this evening
Old 09-07-2018, 06:56 AM   #16
Bennett68C10
No problem, I’ll post them this afternoon after I get home from work.
Keith
66 Suburban
IG: bennett68c10
Old 09-07-2018, 07:46 AM   #17
Hart_Rod
Hart_Rod's Avatar
Thanks!
Old 09-07-2018, 06:22 PM   #18
Bennett68C10
The spacer is 7 3/4” wide and center to center on the bolt holes is 6 5/8”.
Keith
66 Suburban
IG: bennett68c10
Old 09-07-2018, 06:55 PM   #19
Hart_Rod
Hart_Rod's Avatar
Keith - how thick front to back?
Old 09-07-2018, 07:16 PM   #20
Bennett68C10
1 1/2”
Keith
66 Suburban
IG: bennett68c10
Old 09-07-2018, 08:31 PM   #21
Hart_Rod
Hart_Rod's Avatar
1 1/2”
I think that will work Keith. Send me your PayPal. Thanks,
Rob
Old 09-07-2018, 08:38 PM   #22
Bennett68C10
Rob
Sounds good, sent you a PM
Keith
66 Suburban
IG: bennett68c10
Old 09-07-2018, 09:16 PM   #23
Bennett68C10
Spacer sold to Hart_Rod
Keith
66 Suburban
IG: bennett68c10
