Old 07-08-2018, 09:29 PM   #1
Chilly178
Chilly178's Avatar
Radio turns to static when I turn the headlights on
Just like the title says, every time I turn my headlights on my radio instantly turns to static. If I pull the headlight switch one notch to turn just my side markers on the radio does not turn to static, so it only happens when my headlights are actually on. I checked all my grounds and they all look somewhat decent. I have a new retro sound radio, new kick panel speakers, and a new antenna from classic industries, it did the same thing with my old radio as well. I also have some nice led headlights from octane lighting. And yes I have the antenna plugged into the radio. Any ideas? I'm wondering if I should add some grounds or something. It sucks because I can't really listen to the radio if i'm driving at night. Thanks.
Chilly178 is offline   Reply With Quote
Old 07-09-2018, 07:46 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Radio turns to static when I turn the headlights on
What type of distributor do you have?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-09-2018, 07:53 AM   #3
bill3rail
bill3rail's Avatar
If you suspect a ground issue, definitely remove, clean and reattach all grounds. Then add extra grounds! You cannot over ground something.
It did the same thing with my old radio as well.
Thanks.
Just a thought, did your old radio have static with incandescent headlights?
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-09-2018, 08:11 AM   #4
JustToxic
JustToxic's Avatar
New LED headlights produce FM static, and that interferes with your radio. You'll need to get some Ferrite bead choke, or RFI noise filter. You put those around the cable by the headlight plug. You'll have to do some research to find out what ones you'll need for your application. I put LED headlights in my '02 Silverado and my wife's '06 Avalon and needed to put those on both vehicle.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 07-09-2018, 08:33 PM   #5
Chilly178
Chilly178's Avatar
Thanks! It was driving me insane, literally! I will definitely have to look into it. My distributor is a new HEI Ac Delco.
Old 03-12-2019, 11:16 AM   #6
chewychevy67
Did you get the static fixed? I just bought some led lights from octane lighting and if this issue comes up would be nice to know what you did.
chewychevy67 is offline   Reply With Quote
Old 03-12-2019, 11:25 AM   #7
Chilly178
Chilly178's Avatar
I did not. I bought some of those ferrite beads and put them all over and didn't do anything for me. Wonder if anyone else has any other ideas?
Old 03-12-2019, 02:59 PM   #8
chewychevy67
Wow. Wish I read this before I bought them. Probably would have passed on them.
Old 03-12-2019, 03:59 PM   #9
beaterku
beaterku's Avatar
Retro sound radios are very finicky about grounds. Make sure you have an excellent ground for the radio. I chased a problem with the left rotatory shaft for months. Ended up being a grounding issue.
beaterku is offline   Reply With Quote
Old 03-12-2019, 06:25 PM   #10
hjewell2
hjewell2's Avatar
I did a Led lighting conversion in my barn with ballast bypass, and my stereo in the barn has static when the lights are off radio is clear. Its a light hum static as if the station is fading out. The lights are mounted at 8ft high and radio is about 4ft off floor. Noticed it as soon as i did the conversion and during the conversion after the 2nd light fixture was converted. really makes me mad.
hjewell2 is offline   Reply With Quote
Old 04-27-2021, 12:01 AM   #11
Chilly178
Chilly178's Avatar
Not sure if anyone cares but I got the radio static fixed a few years ago and never posted. Tried the beads and they did not work at all... I bought a pair of these and it took care of the problem. https://www.amazon.com/gp/product/B078X1J1MC?psc=1
