Old 07-09-2018, 08:48 PM   #1
lynx5653
lynx5653's Avatar
chassis specs
I am looking for specs on a 86 chassis, are the specs the same from 73 -87 or did they make any changes ? A I can find is specs for 73-80 not sure if they are the same as 86.
Thanks for any and all help
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 07-10-2018, 12:54 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: chassis specs
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-10-2018, 09:11 PM   #3
lynx5653
lynx5653's Avatar
Re: chassis specs
I found specs for an 84 chassis and none of the front end dimensions match my chassis which is suppose to be and 86. I don't have any pics of my chassis to post but I did post specs for the 84.
Can anyone confirm any of the dimensions from cross member to front of frame. Also are these dimensions suppose to be the same for 73-87?
Daily driver
Old 07-11-2018, 02:30 PM   #4
Keith Seymore
Re: chassis specs
I would suggest they would be the same '73-80, and then '81-87, due to the bumper change (and corresponding change to the ends of the frame rails and bumper horns). I would expect them to be (functionally) the same between the wheels, except for the addition/deletion of attaching holes and the bash for the catalytic converter.
You will also need to check apples to apples in terms of model type; that is, compare a C10 to a C10, or a K20 to a K20, etc.
K
1979-1986
1986 - 2019
