Old 07-09-2018, 09:52 PM   #1
DD1
Track Bar Bushing Question
I am replacing the bushings in the Track Bar on my truck. I removed the Track bar and on one end the metal sleeve on the inside of the bushing is stuck on the bolt. I would prefer to use the new sleeve that came with the bushings, but will reuse the old one if I have too.
Any thoughts on how I can get this sleeve off the bolt without damaging anything else? Or should I just reuse the old sleeve?
Any help would be appreciated. Thanks!
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 07-10-2018, 06:59 AM   #2
PGSigns
PGSigns's Avatar
Re: Track Bar Bushing Question
Heat it and get it spinning with a pipe wrench. Before you make the decision on just reusing it check the size to make sure it is the same as the new one. Also your new bushing may have a washer that goes on both sides.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-12-2018, 12:20 PM   #3
DD1
Jimmy
Thanks, I appreciate the help. I will give it a try this weekend.
Darien
1971 C10 LWB
Old 07-13-2018, 04:30 PM   #4
DD1
Jimmy
Jimmy,
Thank You! I just tried your suggestion and it worked like a charm. Took less than 5 minutes to get the sleeve off. I really appreciate the help.
Thanks,
Darien
Darien
1971 C10 LWB
Old 07-15-2018, 05:02 PM   #5
DD1
Does anyone know the size of the upper bolt for the track bar?
Darien
1971 C10 LWB
Old 07-15-2018, 08:59 PM   #6
PGSigns
PGSigns's Avatar
I think it is 5/8-11 about 2 1/2" or so long. Glad the suggestion worked out.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 07-15-2018, 09:15 PM   #7
DD1
Jimmy
Thanks Again!
Darien
1971 C10 LWB
