Old 07-10-2018, 10:55 PM   #1
GMC85HighSierra
GMC85HighSierra's Avatar
Trans/T-case Questions
Hello, I have been doing research on the automatic 73-87 trans/t-case setups. Attached is the information I have gathered. The only part I'm not sure on is the output shaft stickout length for the 700R4. I read that it sticks out 2" further than the TH350 to the NP203/NP205. Just seeing if the information I found is accurate. Thanks
GMC85HighSierra is offline   Reply With Quote
Old 07-11-2018, 08:06 AM   #2
Greenlee
Greenlee's Avatar
Re: Trans/T-case Questions
You planning a swap? Not sure if this helps, but went from a a 700r4 with NP208 to a TH400 with NP208 and the length was essentially the same. I assumed I was going to need drive shaft work, but the old one fit just fine.
Greenlee is offline   Reply With Quote
Old 07-11-2018, 08:08 PM   #3
GMC85HighSierra
I'm not really doing a swap... I'm building a crew cab from the main pieces (the cab, front clip, and frame/axles; no engine/trans/t-case on the frame). I have a 400 engine for my crew cab, but looking at getting a TH400/NP208 combo for it. I have a 2WD TH400 HD trans, but obviously the output shaft is different than the 4WD. Might have this combo soon at my place; awaiting reply for the guy who has the combo.
I just wanted to have these measurements on hand in case I do need them for the future. The only one I didn't find directly was the 700R4 output shaft
stick out length. I attached a pic of what I'm looking for (trans is aTH350 pictured; need measurement for 700R4). Thanks
Old 07-11-2018, 08:16 PM   #4
GMC85HighSierra
Here's the pic (forgot to attach it). Thanks
Old 07-11-2018, 10:29 PM   #5
abig84
abig84's Avatar
Might even be more then 2 inches. You can probably measure the thickness of the th350 to np203 adapter which is like 3/4 inch thick and minis that off how ever thick the 700r4 to np208 adapter. Not quite sure if that would be accurate thougn
abig84 is offline   Reply With Quote
Old 07-12-2018, 08:04 PM   #6
GMC85HighSierra
Yeah I was just looking for the stick out length on the 700R4 attached to an NP208. I read you need a 2" spacer to be able to use a 700R4 with a NP203 or NP205, so I assumed take whatever the length of the output shaft on the TH350 is and just add 2" on to it. So I came up with 2 7/8". Thanks
