Old 07-11-2018, 08:30 PM   #1
NC_John
NC_John's Avatar
Air Intake Support
What are you guys using to support your air intake setups (non-stock). I'm trying to figure out the best way to support a 4" pipe/k&n setup. I got a nifty spectre kit that was advertised as fitting a 4" pipe but the loop it used to hold the pipe was only 4" (exact same diameter as my intake pipe) so it didnt work.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 07-11-2018, 08:39 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Air Intake Support
I used a piece of the intake pipe and built a cradle to support the tube...hose clamp around it holds it solid...the cradle bracket bolts to the core support....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-11-2018, 08:43 PM   #3
NC_John
NC_John's Avatar
I'd appreciate a pic of that if you have one and have time.
1970 C-10 LWB "Blu"
Old 07-11-2018, 09:01 PM   #4
mongocanfly
I made it from aluminum and painted it black....i put a piece of blue tape on it so you can see it better....and of course the pics are upside down
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-11-2018, 10:29 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I riveted a little hook on the end of intake pipe and hooked it into my core support (my core has a hole in it for the intake to fit through.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-13-2018, 12:59 AM   #6
Bird dog
I made an aluminum support that bolts to the core support and to a small tab I welded to the intake tube. I just picked it up from powder coating today so Ill get it installed and take a pic tomorrow.
Bird dog is offline   Reply With Quote
Old 07-13-2018, 06:04 AM   #7
homemade87
My intake is on the passenger side . Picture is a little dark but if you study on it you will see one mount point on the head and another forward of it on the belt tensioner bolt . Both points come to a Y then to the intake . I had a small flat thin piece I hammered into the size of the intake tube and welded a couple tabs to put a bolt in . Doubles as a MAF harness holder . The rods were a couple fender support rods I cut up . Just stuff I had laying around .
homemade87 is offline   Reply With Quote
Old 07-13-2018, 01:41 PM   #8
Nodnarb76
Nodnarb76's Avatar
I used a kit from Spectreperformance.com that allowed me to bolt it to the radiator support.
https://www.spectreperformance.com/s...aspx?prod=9702
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 07-13-2018, 02:12 PM   #9
NC_John
NC_John's Avatar
Thats the one I bought and hoped would work but it wouldn't fit my 4" aluminum intake pipe.
1970 C-10 LWB "Blu"
Old 07-13-2018, 02:14 PM   #10
NC_John
NC_John's Avatar
Dang. Looks like nearly everybody is having to fabricate something. I'll do some more digging and see what I can figure out. My ability to fab something that I will be HAPPY with is pretty limited. Got some stuff at work I can mess with but it'd probably look more at home on a tractor than on my hot rod....
thanks guys- I really appreciate the input
1970 C-10 LWB "Blu"
