86 c10 drop
LOOKING AT DJM 5/5 DROP KIT WITH SPINDLES, COILS AND FLIP KIT.
MY QUESTION IS CAN I RUN 15 INCH STEEL WHEELS ON FRONT WITH OUT HAVING TO MODIFY THE CONTROL ARMS ? 15x7 STEEL WHEELS WITH 1" THICK ROTORS. 3" DROP ON SPINDLE AND 2" DROP ON SPRING. PICTURES ARE APPRECIATED THANKS IN ADVANCE |
Re: 86 c10 drop
I used 3" dropped spindles on a 77 and 82 c10. I had to grind the lower arms on both of them. I used the factory steel rims, not sure if it was a 6" or 7". Grinding it was easy.
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
Diggin The SquareLife
Re: 86 c10 drop
Avoid djm junk only spindle you can run with a stock 15x8 rally is western chassis
