Bendix Stromberg carb replacement
Hi all,
I have a 1966 GMC 3/4 ton pickup with 305 V6 big block. The Stromberg carb has had it and I’d like to replace but having tough time finding a 2bbl carb that will fit to current intake manifold. I like the Holley 2bbl #7448 350 CFM. The current four bolt pattern on manifold is 3 1/4 X 1 7/8. I tried to find an adapter to accept the Holley carb but had no luck. Any advice? Should I have an adapter machined to fit current manifold or replace the manifold in order to mate with Holley carb? Thx Tjmac23 |
![]() Join Date: Feb 2011
Re: Bendix Stromberg carb replacement
Welcome TJMac!
![]() Here is link from the Jolly page showing how its basically done. http://6066gmcguy.com/holley.html You will need this style adapter and if you wish, open up the base to match the adapter. https://www.summitracing.com/parts/mrg-1937mrg Most have used the Holley 500 and good info here as well; https://6066gmcclub.com/index.php?
MusicMan70 1961 GMC Suburban |
Much help ...Thank you. Would you recommend Holley 350 CFM or 500? I’m not looking for speed obviously but just want better engine performance.
Most of the others have reported better results with the 500.
![]() Join Date: Nov 2007
500 Holley works great on my 305 V6 GMC, highly recommend doing the HEI conversion, the info is on Jolly's site.
Tim |
| Bookmarks |
