Old 07-13-2018, 03:30 AM   #1
Rich_65GMC
Rear half shafts
Good day everyone.
Been battling a leaky rear shaft oil seal. Pulled out the half shaft and the seals looks new, as did the rear shoes. Which makes me think this has been done recently possibly just before I bought it.......
Looking at the half shaft there is a small area of galling around where the seal would sit and measuring the diameter of the shaft it's 15 thou undersize compared to the spec of the seal which is a timken 8477s.
My next thought was to order a couple of new shafts but I can't seem to find the right one. The axle is 30.125 inches from the spline side of the wheel end to the spline end but I have a 6 lug wheel and it is also a 12 bolt diff.......
Any ideas on where I can get a pair of these??
Thanks again.
Rich_65GMC is offline   Reply With Quote
Old 07-13-2018, 04:31 AM   #2
Killer Bee
Killer Bee's Avatar
Re: Rear half shafts
speedi-sleeve/redi-sleeve or machine seal land and adjust seal size accordingly..
good luck!
Old 07-13-2018, 06:22 AM   #3
PGSigns
PGSigns's Avatar
Post a picture of the end of the axle so we can see if it is bearing wear or the seal area worn. If it is bearing area you will need axles. Also let us know the year of the truck and the spline count.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-15-2018, 06:04 PM   #4
bama63
bama63's Avatar
these usually work https://www.rockauto.com/en/moreinfo...sn=633&jsn=633 these move the seal and bearing over slightly on the axle to an unworn area hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
