Old 07-13-2018, 05:25 AM   #1
bikernut
bikernut's Avatar
Fuel Gauge
my 2003 4x4 3500 6.0 with dump body has dual factory fuel tanks. It just started to show that it is empty and the low fuel light is also on. I filled both tanks as I usually do and it didn't rise to full mark. What does this tell me that the gauge is junk and needs replacing? Does this have only 1 fuel sending gauge and is it in the main front tank. When first turning on the ignition the gauge does go to about 1/8 tank or so and then quickly falls back to empty. Could this also be just a grounding problem and how do you check for either a bad gauge or bad ground. I know years ago when the gauge showed empty it meant that it was lacking ground and if you grounded it the gauge went to full does this still hold true on the newer trucks or has that gone by the way side with the advent of the computer controlled GM vehicles?
2020 GMC Acadia Denali (Maroon)
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ 41KG Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike ( Maroon)
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 4x4 Blazer (Dark Red)
bikernut is offline   Reply With Quote
Old 07-19-2018, 08:26 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Fuel Gauge
I would be removing all ground straps and cleaning the areas of contact with a wire wheel and sand paper, then replacing each...
Make sure you do the body to chassis ground straps...as the dash grounds through the body....
If no improvement, pop out the sender unit and make sure the float hasnt fallen off...seen it before...
AussieinNC is offline   Reply With Quote
Old 07-31-2018, 01:11 PM   #3
notsolo
notsolo's Avatar
Re: Fuel Gauge
I grounded my tank to frame, that didn't work....grounded sender. That worked. Good luck.
notsolo is offline   Reply With Quote
