Old 07-14-2018, 01:40 PM   #1
Spurgin1
292 Engine mount
Are the engine mounts the same on 292 as 250. I know the passenger frame mount is different. Thanks
Spurgin1 is offline   Reply With Quote
Old 07-15-2018, 12:25 AM   #2
Captainfab
60-66 Nut
Re: 292 Engine mount
The engine mounts themselves are the same '63-'72 for the 230,250, 292, 283, 307, 327 and 350's
Old 07-15-2018, 11:22 AM   #3
Spurgin1
Am I missing spacers or something? It likes about an inch being long enough to set on the perch.
Old 07-15-2018, 02:07 PM   #4
padresag
are you sure it is a 292??
ron
padresag is offline   Reply With Quote
Old 07-15-2018, 03:36 PM   #5
Spurgin1
ron
Positive
Old 07-15-2018, 05:55 PM   #6
padresag
show a picture of the mounting in question. it is either one way or the other.
ron
Old 07-16-2018, 12:07 AM   #7
Captainfab
60-66 Nut
Do you have the brackets between the block and the engine mounts?
Old 07-17-2018, 07:35 PM   #8
padresag
it sounds like someone using a 292 perch on a 230-250 eng. there are only 2 different perches in 2 wd and 2 different engine applications. if it don't match up with one it must be the other. there were no other options. he may be also trying to fit a gmc perch in there but do not know what that outcome would be but doubt that it would work.
ron
Old 07-18-2018, 09:44 PM   #9
dmulally
I had dramas with mine as somebody had butchered some BB mounts to fit the brackets for a 250. So when I put a V8 in it was about an inch out.
I got rid of it all and went for a tubular mount that moved the engine forward for the MSD cap.
dmulally is offline   Reply With Quote
Old 07-18-2018, 09:56 PM   #10
padresag
but we so far can only go by the info that has been given and it is skimpy. n o one has mentioned anything other than a stock applications so far. he has been asked on 2 forums for pictures and hasn't done so yet. if pictures are given then the problem may be solved
ron
