Old 07-14-2018, 03:20 PM   #1
63frankintruck
Radiator Core Support Bushings?
I'm looking for core support bushings for 63 C10.
I think they just leather pads in there when I pulled it apart years ago. What are you guys using?
Also is there a place to get them where I dont have to pay more for shipping than what the parts cost?
63frankintruck is offline   Reply With Quote
Old 07-14-2018, 06:39 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Radiator Core Support Bushings?
Best off make a list of parts you need and buy them all at one time Then the shipping it more better
stsalvage is offline   Reply With Quote
Old 07-14-2018, 07:06 PM   #3
Short 3/4
Assuming that the 63 uses the same ones as 64,5,6 which is what I'm familiar with, Be aware that the top and bottom ones are slightly different. Factory bottoms have a divot to clear the rivet, while tops do not. Some aftermarket ones do not have this feature, so is worth paying attention to. A correct bottom will work fine on top, but a top will not fit well on the bottom.
Hope this all makes sense,
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 07-15-2018, 12:29 AM   #4
Captainfab
60-66 Nut
The radiator support bushings are the same '60-'68.
https://www.classicparts.com/1960-68...info/78%2D625/
Old 07-15-2018, 07:37 PM   #5
Short 3/4
Where the heck do those go? I thought he was talking about those U shaped rubber thingys.
292-SM420-T221
Old 07-15-2018, 08:43 PM   #6
PGSigns
PGSigns's Avatar
They go between the core support and the frame rails.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-16-2018, 12:41 AM   #7
Short 3/4
Jimmy
Oops, I was thinking of wrong part,
Never mind.
292-SM420-T221
Old 07-16-2018, 09:43 AM   #8
Robert Haas
I built these out of aluminum, did not see the need for isolation.
Robert Haas is offline   Reply With Quote
Old 07-16-2018, 09:52 AM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
And you could sell those "if" they were the correct height for every truck. I dont know the answer to that myself.
