![]() Join Date: Apr 2010
DT Tri-Y and CEL
Hi Ya'll,
Its been a couple months since I last posted here, but I'm trying to fix a CEL issue for O2 sensors withthe DT Tri-Y ceramic coated headers. The codes are always "Slow response" for both sides. DT mentions: "INSTALLATION NOTES Installation of these headers will trigger a CEL (check engine light). This minor problem can be corrected with either a performance tune or tuner, and/or an o2 sensor simulator offered by many companies in the aftermarket." I'm getting a tune this next week but wanted to know if this is the only fix for this issue. I have this issue on both an LM7 (2002) and a LQ4 (2006) with the same 3/4" diameter Tri-Y headers. Thanks for any insight ya'll may have! John
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
BMW & ASE Master Certified
Re: DT Tri-Y and CEL
An o2 sim on the pre cat would be pointless.. the point of the pre cat se does is to measure the oxygen in the exhuast.. the computer calculates and makes changes. A sim
. Well.. it wont.. A performance tune sounds like an SD tune? I would ask DT if that's what they meant.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
meowMEOWmeowMEOW
All they mean is that a tuner will disable reporting for those codes. I.E the problem won't change, you just won't see it anymore.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Apr 2005
Interesting. I've run several sets of these headers and never had an issue with 02 sensor codes. Were the rear O2's turn off in your tune?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
| Bookmarks |
