62 235 truck motor
I messed up and added a quart too much oil.
Problem? |
Re: 62 235 truck motor
When I did that to my wife's '01 Altima, I drained the excess into something clean and used it to change the oil in my lawnmower. I couldn't believe it only held 4 quarts. It's an easy fix, why risk it?
![]() ![]() ![]() Join Date: Jan 2018
Too much oil actually kills horsepower, and can do harm to your engine. An episode of Engine Masters by The Motor Trend Group showed how much power was killed by being one quart over full. Also, as the crank is spinning, if there is too much oil, the crank can spin through the oil and cause aeration of the oil which will make air bubbles in the oil. That can lead to a decrease in oiling capabilities
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
It will be ok, I run a little more in my 235. My machine shop told me to.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
Moderator
![]() Join Date: Dec 2012
Normally, I'd say just pull and dump the filter... But...
