Old 07-18-2018, 08:06 PM   #1
Dagobah
battery relocation spots for 69 stepside
Howdy errbody. I am looking to relocate the battery on my 1969 GMC stepside. Also, it is a short bed. The goal is to move weight off of the front end, so anything behind the front wheels would be an improvement.
Originally I thought about mounting it to the firewall. I don't see a lot of people doing that. I've also seen them mounted inside the cab behind the seat. I'm not sure about that. I don't know if sealed batteries have to be vented.
Ideally, it'd be down low and between the front and rear wheels with reasonably easy access. I see people mounting them to their frames, but I think that's always on fleetsides. Your suggestions are much appreciated.
Dagobah is offline   Reply With Quote
Old 07-19-2018, 03:15 PM   #2
BRL
BRL's Avatar
Re: battery relocation spots for 69 stepside
Surprised nobody replied to this yet, I would like to see any ideas out there too.
BRL is offline   Reply With Quote
Old 07-19-2018, 04:49 PM   #3
slowcpe
slowcpe's Avatar
While I haven't actually done this yet, my plan is to mount on the frame just behind the rear tire on the passenger side. It "should" fit.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-13-2018, 09:25 PM   #4
Dagobah
Kind sir, I scanned through your two truck threads to see if you had any pics. Any progress on your battery relocation?
Old 12-13-2018, 11:01 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: battery relocation spots for 69 stepside
These are not mine but off the internet for idea's.
Just remember the further you mount it away from the motor the bigger gauge cables you should use.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-13-2018, 11:47 PM   #6
68gmsee
Active Member
68gmsee's Avatar
An internet search for "67-72 chevy truck battery relocation" and clicking on images shows several location possibilities. If you add "kit" at the end you get some mounting kits for relocating the battery.
The stock location of the battery on these trucks is not the best area. I see a lot of corrosion on the hoods directly above the battery in many trucks. However, the concern I would have with relocating to the frame is water splashing on the battery terminals and maybe causing a short.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-14-2018, 12:44 AM   #7
C-cab23
C-cab23's Avatar
I don't think there is a problem with water shorting the battery...I have a Chevy ssr and the battery is located behind the rear end....that's the way it came from the factory..
1968 GMC stepside long bed
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1946 Chevy 4 door sedan
1923 C-Cab
C-cab23 is offline   Reply With Quote
Old 12-14-2018, 09:32 AM   #8
Mike C
Mike C's Avatar
As I prepare to fix ANOTHER rusted battery tray and inner fender well, I highly recommend getting away from lead acid batteries and going AGM. You can also mount an AGM battery at any angle.
Have you looked at going to a lightweight battery instead of relocating it? I think some of the Odyssey batteries weigh around 10#?
I am an Optima fanboy, but they don’t do anything to help you with weight.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-31-2020, 10:49 PM   #9
Dagobah
Going with a lightweight battery would probably be the most straight-forward way to go. The other idea I was thinking about was putting the battery in the toolbox, but here's the catch:
The toolbox I'll have in the truck was hand-made by my grandpa who bought the truck new. Now I'm starting to think I shouldn't drill holes in it. I don't know.
Old 01-31-2020, 11:46 PM   #10
randy500
Put it on the step
randy500 is offline   Reply With Quote
