![]() Join Date: Apr 2010
22” Alcoa’s on a 3/4 ton rear end?
Has anyone used a 3/4 ton single wheel rear end and used the 8 to 10 lug adapters to run 22” or 24” Alcoa wheels on? Or do I need to continue looking for a 1 ton dually rear end?
Thanks, Wade |
Re: 22” Alcoa’s on a 3/4 ton rear end?
Thats what im using 3/4 ton rear, 8-10 lug adapters with 22" semis. I swapped out my 1-ton rear for a 3/4 suburban rearend. The sub rear is narrower so i can use the factory dually rear fenders and the semi wheels will tuck
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
Pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Exactly what i am running.
It followed me home?
Why not a single 1 ton srw axle? Wouldnt that be easier than having to move spring perch's and shock mounts?
^^ Killer truck!!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Awesome truck!👍🏻
Wade |
Did you have to change the wheel studs to be long enough for the adapters?
Wade |
I replaced because i was there.
Yes, that works also. I have done 3.
| Bookmarks |
