Old 11-14-2003, 03:23 PM   #1
Olden Days
Living In The Past
Olden Days's Avatar
leafs or coils?
as some of these 2wd trucks come with leafs, I was wondering why? what makes the better comfort ride? which is more desired?Leafs or coils? thanks jerry
Olden Days is offline   Reply With Quote
Old 11-14-2003, 03:27 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
There is a discussion about this here
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-14-2003, 03:30 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Coil springs do ride better, and don't have wheelhop like leaf springs do. Coil springs also usually plant the power to the ground better.
The only real disadvantage in truck use is that the coils aren't that good at hauling loads. My truck squats with like 200lbs in the back. I have hauled an estimate 2000+ lbs in it before, and it pulled it just fine but my back bumper was barley off the ground.
So, IMO, if you are gonna drive the truck every day, coils are the way to go. If you are going to use the truck to haul loads, leafs are better.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-14-2003, 05:10 PM   #4
rambler
MOVE OVER
rambler's Avatar
I'm putting overload leaf springs on the back of my coil spring truck,, should be the best of both worlds..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 11-14-2003, 05:53 PM   #5
Jwill41
Jwill41's Avatar
I have 67 GMC with leafs and a 68 Chevy with coils and the ride is much better with the coils. The 67 is a short bed and the 68 is a long bed so that might make some difference in the ride. I have never had much of a load on either one so dont know about that. I have heard that the coils will bottom out and haul whatever your tires can handle. It seems to me like the leafs would bend with too much weight.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
