Old 07-20-2018, 08:34 AM   #1
solidaxel
solidaxel's Avatar
Aftermarket Electric Speedometer
For those of you that have added a speedometer controlled by your ECM
What brand of speedo are you using ?
What is the signal that is produced by the ECM?
Does the transmission VSS make a difference if it is a 4L60E or a 4L80E
or is the "magic" controlled by the ECM and not the VSS?
What Pin or Pins control the speedometer and what is the signal that is transmitted to the speedometer?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-20-2018, 12:59 PM   #2
dayj1
Re: Aftermarket Electric Speedometer
I'm going to assume we're talking about Gen 3 PCMs since that seems to be what most folks are using.
The PCM outputs a square wave with an amplitude of 12V and a frequency that varies with vehicle speed on pin 50 of the red or green connector (depending on whether you have a "red/blue" or "/blue/green" PCM).
The VSS output defaults to 4000 pulses per mile (4K ppm), but can be changed in the tune.
4l60 and 4l80 both have 40 tooth reluctors on the trans output shaft and the VSS sensor reading the teeth on that reluctor wheel outputs an AC sine wave that increases in both frequency and amplitude with speed.
Most speedometers are going to want the square wave from the PCM and not the sine wave directly from the VSS.
dayj1 is offline   Reply With Quote
Old 07-20-2018, 06:26 PM   #3
solidaxel
solidaxel's Avatar
I have a combination of a 2003 4l60E and a late model LS3
Thanks with that info I think I can answer his questions
I don't have the ECM in front of me but is a new ECM and the engine runs and the trans shifts, working on the dash speedo and Tach next
I can get an electric conversion for the tach but I can only use the stock speedo "Face"
which has a 180* sweep
LS 3 4L70E
Old 08-06-2018, 12:43 PM   #4
solidaxel
solidaxel's Avatar
Will there be a description on the aftermarket speedo to indicate what signal it needs to make it read MPH
LS 3 4L70E
Old 08-06-2018, 06:40 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used a Dolphin electronic, 8k was the setting I believe.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
