![]() Join Date: Jul 2001
Replace Cig. Lighter Element
Have tried several times to replace/remove the element from my original GM cig. lighter in my '71 4x4. Does not work, wiring is good to the lighter housing with solid 12 volts. Can only figure the element is burnt out? Any one have a clue as to how to remove from the lighter knob and replace with a new element? Not having any luck removing it. Seems simple enough to accomplish but can't get it done. Thought all the old knobs and elements were serviceable replacement style?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#2 | |
![]() Join Date: Jan 2012
Re: Replace Cig. Lighter Element
![]() Join Date: Dec 1999
The button will unscrew from the element. But the element is pressed or glued to the black metal disc. My element was good. So I removed the button sanded the disc, masked it off and repainted it. I would guess if the element is shot one might be able to punch it out of the disc and find a replacement element. But might need to find another means to attach it.
Smitty '71 Short Fleetside Spring Valley, Ca. |
Thanks Smitty, removing the button will make it much easier to mask the black area off and repaint.
Found that I had to use some medium with water pump/slip joint pliers on the black portion and another protected pliers on the chrome button so as not to mar either portion. Because they can be pretty stubborn about be parted after 40+yrs.
I got lucky. Mine came apart with my hands. What paint did you use for the black part?
cericd, thanks for bringing this thread back and now we even have an answer to the question. Since I don't smoke and haven't for a good many years the lighter not working was no big deal. The 12 volt power source for my cell phone was all I needed. Glad you got an answer thanks to Smitty. Good info if one can find a replacement element or want to spruce up the looks of a lighter.
Thanks to you also Smitty for the info. May have to see if I can get lucky to separate my lighter at some point. ![]()
There was another post recently. Where another member showed how he used an element he got at the parts place. And the way he adapted to utilize the black washes and chrome button. I don’t smoke either but run my kill switch through the lighter.
I'm thankful for the answer too. My truck came with a lighter delete plug and I'm a non-smoker but wanted to add a lighter to use with a cell phone charger as well. Plus, I could use the lighter as a hand warmer since my heater doesn't currently work.
