Old 07-22-2018, 12:49 PM   #1
dtkarst
1961 Apache finally runs
Finally got my 61 Apache up and running again. Spent the 70 bucks and got an hei for it and put a clean tank in it and she fired up. Put a valve cover gasket on it, found an air cleaner for it, new heater hoses, going to go through the brakes next and then lights and such. Had a question though, there’s some wires running through where the dome light wires would run but go out through a hole in the floor I’m front of the tank with a little metal cover over it....what do they do? Lol they’re cut right under the cab so I’m but just to figure them out. Last picture is what I’m talking about. Thanks
dtkarst is offline   Reply With Quote
Old 07-22-2018, 03:08 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 1961 Apache finally runs
Was the rear turn signal light still optional in 61?
Something was saying that was the original route for the backup lamps wires. Generally back up lamp wires are light green. Where do the go in the cab? Light harness?
Old 07-22-2018, 03:10 PM   #3
aerotruk63
aerotruk63's Avatar
Looking in the 61 shop manual , so far pink and blue side by side , no mention.
Old 07-22-2018, 04:29 PM   #4
dtkarst
It’s got a regular turn signal switch on the column. I was thinking that’s what they were for, being the turns and brake lights
Old 07-22-2018, 04:59 PM   #5
72 Highlander
My 61 has same set up, there is a connector they cut off. Its the harness to tail lights and turn signals.
72 Highlander is offline   Reply With Quote
