Old 07-24-2018, 08:28 AM   #1
cebra
Intermittent Wiper Module Options
I need to buy a intermittent wiper module soon and I have not read good reviews on any of them available. I know that a board member makes them but they are on hold for the time being. I am respraying my interior and don't want to drop the column, pull the cluster, etc an extra time to add this in later. Anyone have one from LMC, Brothers, Revolution, or Others and can provide feedback?
cebra is offline   Reply With Quote
Old 07-24-2018, 08:43 AM   #2
Shinysideup
Shinysideup's Avatar
Re: Intermittent Wiper Module Options
This is the easiest to use IMO.
http://www.revolutionelectronics.com...-wiper-module/
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 07-24-2018, 05:15 PM   #3
bill3rail
bill3rail's Avatar
There are simple boards that you can buy and wire it up yourself. Check SleazyBay for them. I will try to post the model later tonight if I can.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-24-2018, 05:20 PM   #4
68 P.O.S.
x2 on Revolution. I haven't used them yet, but their's seems to be the simplest and easiest to use. The have other nice products too
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-24-2018, 06:14 PM   #5
custom10nut
custom10nut's Avatar
One of the board members used to make one, but he’s been on a sabbatical for a while. The revolution one is what I’m going to go with. I did all the research and read the reviews, so to me it’ll be worth it.
custom10nut is offline   Reply With Quote
Old 07-24-2018, 07:31 PM   #6
Hammond68
I've got the revolution electronics through lmc. It works I believe it has a 3-5-8 delay. You keep the same wiper switch. Turn it from low to high back to low quickly to adjust the speed faster. Low to off and back for slower.
Beats constantly reaching for the wiper. You will also still have low speed. It's a module that wires between the plug and switch so everything still looks stock.
Hammond68 is offline   Reply With Quote
Old 07-24-2018, 10:54 PM   #7
HO455
Post Whore
HO455's Avatar
I have the Revolution electronics version it works good. You get 3 delay intervals and the two original speeds (If you have a two speed motor). It took a half dozen trips using it before it became second nature to change intervals. Draw backs are you have to cycle through all speeds to go from the longest delay to the shortest. No infinite speed control so it is like a Toyota system.
Plus's are low cost, you can use the stock switch and keep the washer too. No second control for interval. And it is far cheaper than the New Port Engineering system. (Which looks like it may have a better wiper motor than the stock one.) But you have to have a second switch for a washer with the New Port set up.(As far as I know). I feel it is necessary to disclose that I live in NW Oregon.
RIP Bob Parks.
Old 07-25-2018, 08:28 AM   #8
cebra
Sounds like Revolution Electronics is the consesus, Thanks.
Old 07-25-2018, 03:53 PM   #9
BigBlock67
just bought a New Port ssystem and the washer is part of the wiper switch.Not cheap but seems to work very well and is easy to use.
BigBlock67 is offline   Reply With Quote
Old 07-25-2018, 10:23 PM   #10
ZEKE68
ZEKE68's Avatar
Believe the member on here that sold the intermittent wiper kits was twouvakind. I just installed the kit I got from him and it works well.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 02-22-2020, 05:14 PM   #11
Hammond68
Just took it out. Wipers stuck on. Messed with the plugs and all. Kept doing it. Haven't looked into warranty yet. But I do kind of expect things to last. In and out with the cluster yet again. It wasn't the switch, wipers work after removing intermittent delay.
1972 c10 cheyenne.
383 stroker 10-1
280 magnum comp cams
700r4 tranny.
Old 03-31-2023, 08:15 AM   #12
A1971Blazer
A1971Blazer's Avatar
Old thread here but I just installed the Revolution module on my 67 build.
I made a mounting bracket to get it back out of the way.....I'm not a fan of zip-ties........I had to extend the wires some to make it plug in.
I tested the operation and it works perfectly....just hope it lasts..
I almost hard wired it in...but if it fails....I can simply plug the original connector back onto the switch.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-31-2023, 12:01 PM   #13
HotWheelsFan
HotWheelsFan's Avatar
Looks nice. I am glad to see the operation keeps the original switch and motor with added functionality.
HotWheelsFan is offline   Reply With Quote
Old 04-01-2023, 10:42 PM   #14
HO455
Post Whore
HO455's Avatar
Mine now has over 43k miles in my daily driver Burban. Living in Portland it has seen its fair share of use.
RIP Bob Parks.
