Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 07-25-2018, 10:09 AM   #1
Hart_Rod
Hart_Rod's Avatar
Dakota Digital OBD2 BIM module
**** SOLD! ****
Dakota Digital OBD2 BIM module. $100 shipped. Paypal is robhartley@aol.com
The BIM-01-1 OBD-II (J1850/CAN) Interface allows you to plug directly into the engine diagnostic port, extracting engine and transmission data from the vehicle's computer (ECM). The BIM-01-1 will collect and output the following information to Dakota Digital Instrument Systems *:
Always available:
Speed
Tachometer
Engine Temp
Check Engine Indicator
Vehicle specific:
Intake Air Temp
Transmission Temp
Ambient Air Temp
Gear Position
Oil Pressure
Boost
Please note: Due to the various factory and modified ECM's, additional data including (Intake Temp, Transmission Temp, Ambient Air Temp, Oil Pressure, and Gear Position) may be available, but will vary from application to application. Dakota Digital cannot guarantee the presence or accuracy of the Coolant Temp, Intake Temp, Transmission Temp, Ambient Air Temp, Oil Pressure, Boost or Gear Position displays since this is a function of the ECM and matching OEM functional sensors.
*The BIM-01-1 is designed to decode the information provided by the ECM through OBD-II and supply this information to the VFD3 rev. G, VHX and HDX control box instrument systems only. Earlier control boxes (with an aluminum case) are not compatible with the BIM family of Expansion Modules.
**The BIM-01-1 is designed for J1850 and CAN OBD protocols only. If you are concerned about compatibility with your vehicle please contact our sales or tech department.
http://www.dakotadigital.com/index.c...rod/prd752.htm
Hart_Rod is offline   Reply With Quote
