Old 07-26-2018, 11:24 AM   #1
bigmoe
bigmoe's Avatar
Swapping newer front suspension into 65??
I was told a 73-87 front crossmember/suspension is a good swap into a 65ish truck to get improved ride and ps and disc brakes. I did a quick search but couldn't find the info. Can someone direct me to a good thread showing this install? Pros? Cons? Does it change ride height?
bigmoe is offline   Reply With Quote
Old 07-26-2018, 11:35 AM   #2
PGSigns
PGSigns's Avatar
Re: Swapping newer front suspension into 65??
Look in the FAQ section and it is covered very well. It will not change the ride height. The FAQ section has loads of info on these trucks and is well worth a look through.
Welcome to the forum.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-26-2018, 11:46 AM   #3
raidmagic
raidmagic's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=357610
raidmagic is offline   Reply With Quote
Old 07-26-2018, 12:15 PM   #4
bigmoe
bigmoe's Avatar
thanks guys
Old 07-26-2018, 06:00 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Welcome to the Forum!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-26-2018, 11:37 PM   #6
Captainfab
60-66 Nut
If you want to lower your truck, you can skip the '73-'87 suspension swap and just buy dropped spindles and springs for a '63-'70 truck. I like the '73-'87 suspensions for some of it's upgrades, but most here are more concerned with ride height.
