07-26-2018, 06:17 PM | #1 |
Setting Throttle Cable
What's The Correct Procedure To Setup a Throttle Cable?
Posted via Mobile Device |
07-27-2018, 01:29 PM | #2 |
Who Changed This?
Re: Setting Throttle Cable
What are you running?
The throttle plates should be vertical when the accelerator pedal is on the floor. If you have a Q-Jet or anything else with vacuum secondaries, you'll have to open the secondary air valves in order to check.
07-27-2018, 02:25 PM | #3 |
07-27-2018, 02:26 PM | #4 |
Its An Edelbrock Carb With a Lokar Throttle Cable
