Vanishing Brake Fluid
So the rear half of the master cylinder slowly loses fluid until empty. I suspected that the front wheel cylinders might be leaking, but I pulled back the rubber and they were dry inside. I see no evidence of leakage inside the drum. I have looked and can’t seem to find a leaking line anywhere.
It’s a 69 K25 with PB and drums on all 4 corners. I’m stumped. Ideas? Pump the fire out of the pedal and keep looking, I guess.
1969 GMC K25 2007 Chevy 2500HD Classic Drama 1999 Tahoe 2DR 4WD Base Model 5.7l 1971 Buick Skylark Custom |
Re: Vanishing Brake Fluid
its leaking out of the rear seal of the master into the brake booster
1970 short step c10 leaf spring 454 |
Thanks, brother!
1969 GMC K25 2007 Chevy 2500HD Classic Drama 1999 Tahoe 2DR 4WD Base Model 5.7l 1971 Buick Skylark Custom Last edited by Hotcorner; 07-27-2018 at 09:24 AM. |
![]() ![]() Join Date: Oct 2014
Did you also check your rear wheel cylinders? I'm assuming you see no leaks under the truck either. If not, then I suspect what Volksworld said is probably the case. Disconnect the master cylinder from the power booster and see if you see any fluid there.
![]() Join Date: Feb 2014
All good advise. I have a truck that would suck the fluid through the vacuum hose and burn the brake fluid, with very little evidence. There was an internal hole/defect in the seal/bladder in the vacuum canister of the power brakes. Just an idea if all other sources check out okay, Bruce
Rear cylinders are good. Replaced a couple months ago. No leaks, other than motor and t/c.
![]() Join Date: Jan 2018
Correct, Sir! Ding ding ding? $60 for a new one. $30 for reman.
I know. I don’t buy much reman because I prefer to only fix a problem one time. Had already gotten a brand new one.
| Bookmarks |
